Old 01-20-2007, 12:15 AM   #1
Litemup
Steel Horse Cowboy
Litemup's Avatar
Doing away with points. What should I get?
I'm still preatty new here and learning, that being said I'm going to be doing a points swap out on a 350 in the near future and I thought I would get some recomdations from you guys I'm sure just about everyone has tried everything.
My creteria: Money is'nt a super big option but I don't really want to spend more that 400 bucks on a distibutor. I wan't the engine to produce roughly 425 hp. Lastly if you could include everything you need when you buy it that would be great, like and MSD that needs a controller.
Thanks I'm curious to see what you guys think is the best out there.
Litemup is offline   Reply With Quote
Old 01-20-2007, 12:29 AM   #2
Billla
Billla's Avatar
Re: Doing away with points. What should I get?
I did the Pertronix conversion on my points distributor and it's been trouble-free. Only PITA was getting the clearance right on the reluctor disk; it just took a little while to tweak.
http://store.summitracing.com/egnsea...115+4294845520
Certainly better choices given the HP level and budget, but I just wanted to throw this in the mix.
MSD StreetFire HEI with an MSD 6A would be my suggestion - but you'll be a bit over $400, not including wires.
Billla is offline   Reply With Quote
Old 01-20-2007, 12:31 AM   #3
Litemup
Steel Horse Cowboy
Litemup's Avatar
A friend of mine actually used the exact same unit on his old ranger, he has preatty good things to say about it, but also said if he had a bigger budget he would probably gone another way.
Has anyone ever used this?
http://www.jegs.com/webapp/wcs/store...57040_-1_10679
Opinions?
Old 01-20-2007, 12:32 AM   #4
chopper103in
chopper103in's Avatar
heres a dizzy that should work good for what you want
http://cgi.ebay.com/ebaymotors/NEW-P...QQcmdZViewItem
chopper103in is offline   Reply With Quote
Old 01-20-2007, 12:37 AM   #5
short69
short69's Avatar
I would suggest the same MSD combo as Billa.I have never had any of their products, but MSD seems to have some good stuff. I swapped my points for a Mallory HEI and it works fine,but then again probably any HEI will be way better than points!
69 shorty w/ 67 front clip
short69 is offline   Reply With Quote
Old 01-20-2007, 12:38 AM   #6
Litemup
Steel Horse Cowboy
Litemup's Avatar
Originally Posted by short69 View Post
I would suggest the same MSD combo as Billa.I have never had any of their products, but MSD seems to have some good stuff. I swapped my points for a Mallory HEI and it works fine,but then again probably any HEI will be way better that points!
That's what I'm thinking, I've had points in the past, and they work preatty good but they just don't last long and require adjustments often.
Old 01-20-2007, 12:46 AM   #7
poorboy
poorboy's Avatar
I would go with a MSD box and dist. You can find good deals on used ones and they are easy to install.
poorboy is offline   Reply With Quote
Old 01-20-2007, 12:49 AM   #8
Litemup
Steel Horse Cowboy
Litemup's Avatar
I actually found some good deals on the Pro billet HEI dist. You guys think that's better, or is the street fire with a control box better?
Old 01-20-2007, 10:54 AM   #9
Billla
Billla's Avatar
The Pro Billet Streets are nice; I've used one before. I'll probably kick off a huge debate, but you DO want vacuum advance for a street-driven small block unless it's ProStreet level...which at 425 HP I assume it's not.
Old 01-20-2007, 08:48 PM   #10
kevenj
If you want it to look stock go with a pertronix igniter in your points distributor; but if that's not important to you then I'd say go with either a stock HEI (if you can find a good used one) or a brand new HEI from Mallory, Accel, or the like. I've got the Mallory in mine; all the parts (module, pickup coil, ignition coil, cap rotor) are standard GM HEI parts that you can get at ANY parts store in the country if you ever break down in B.F. Egypt. My engine is built fairly mild, but I'm also running a stock HEI distributor in my jet boat that has a very healthy LS6 454 in it - - works great!
kevenj is offline   Reply With Quote
Old 01-20-2007, 01:00 AM   #11
poorboy
poorboy's Avatar
A friend of mine ran one for years and never had a problem with it.
Old 01-20-2007, 03:26 AM   #12
Litemup
Steel Horse Cowboy
Litemup's Avatar
I have a few questions, I was looking around and all of the HEI dist that I see don't require the control box, is that something you just add yourself anyway? Do you think you guys could point me to some links of what your talking about. I found these:
http://store.summitracing.com/partde...5&autoview=sku
Do these two work together, is there anything else I would need, besides wires?
Old 01-20-2007, 04:30 AM   #13
ghackett1
68 C10 Longbed
ghackett1's Avatar
I've had great success on a few different engine combinations with the MSD Ready To Run Distributor. Drop in, One wire to each side of the coil and one to your 12volt source and your ready to go.
ghackett1 is offline   Reply With Quote
Old 01-20-2007, 08:29 AM   #14
mnunn454
mnunn454's Avatar
I've heard great things about MSD controller boxes. However, I'm running plain stock HEI distributors in both my 454s and they run fine. (i.e with no misfires up to 6K RPMs, inexpensive to maintain, no big controller box hanging on the firewall). Would an MSD box give me better performance? Very likely, but in my particular situation, the few % extra in various parts of the spectrum is hardly worth the extra money.
What I do miss (that I'd get with the MSD-6AL box) is the rev limiter. I'll eventually add one of these when I'm ready. I'll then choose between the 6-AL box or some other kind of rev limiter.
Just another opinion here to toss in with those above, for the money I'd put a nearly stock HEI distrib in it and spend the extra money on the induction system (Heads, intake, rockers, cam etc). I think you'd see more [HP/TQ] return for your investment.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 01-20-2007, 09:13 AM   #15
gator2511
gator2511's Avatar
I used a Mallory Unilite Dist. with a MSD 6A box. When I put that in, the engine really lit up! Probably it would be better to use the 6AL with the rev limiter. I used a shift light on the column and shifted at 6500 rpms on a daily basis. Whatever dist. you get, the box would be an asset for sure.
gator2511 is offline   Reply With Quote
Old 01-20-2007, 10:37 AM   #16
truckdude239
truckdude239's Avatar
http://cgi.ebay.com/ebaymotors/CHEVY...mZ260074075382
i got one of these from skipwhite on ebay alot of other people on here have too and love them. just remenber to run a new 12v power wire that is only hot with key on DO NOT use the yellow wire it only runs 9 volts and will burn the modual out
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
