01-20-2007, 12:41 AM | #1 |
Best way to clean power steering pump
I took my power steering pump off so I can get the brackets powder coated and figured I would clean up the pump as well. One of the hoses had a slit in it so the bottom has a buildup of power steering fluid. What can I use to get that off of there?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-20-2007, 12:44 AM | #2 |
Re: Best way to clean power steering pump
You can use a solvent tank or spray it off with parts cleaner and an air hose. Whatever method you use make sure you don't get any of the solvent or cleaner inside. I don't think the seals would like that.
01-20-2007, 01:09 AM | #3 |
I dont have a solvent take. What kind of parts cleaner could I use?
01-20-2007, 01:11 AM | #4 |
can spray it down with brake clean or carb clean and use a wire brush to scrub with
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
01-20-2007, 01:17 AM | #5 |
I have both of those. Will give it a try. Thanks much...
01-20-2007, 01:20 AM | #6 |
your welcome and goodluck
