Old 01-20-2007, 05:30 PM   #1
sixtysevengmc
village idiot
sixtysevengmc's Avatar
manual trans cross member?
I need to know if the manual trans cross members are the same for three and four speeds?
I've found a x member in a 67 3/4 ton I6 four speed(granny) and want to know if it will work with my V8 bell-housing.I was told that the three speed trucks didn't use a x member but had plates that bolted between the frame and the bell-housing.
thanks
sixtysevengmc is offline   Reply With Quote
Old 01-20-2007, 05:55 PM   #2
jsbgump
Gone Fishing
jsbgump's Avatar
Re: manual trans cross member?
I believe they are
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 01-20-2007, 06:46 PM   #3
Troy-Built
The cross member is the same but the three speed bellhousing pilot hole is smaller than 4 speed one.
69 Chevelle SS 375/396 TKO 600
71 Suburban 3/4 4x4 402 5-speed (project)
68 chevy C10 shortbed 327 5-speed (project)
72 Blazer 4x4 400 4-speed (wifes project)
Numerous 67-72 parts trucks
Troy-Built is offline   Reply With Quote
Old 01-20-2007, 09:19 PM   #4
crazy longhorn
Fabricate till you "puke"
The crossmember is the same for 3 or 4 spd....if they are both a 6cyl, or both a sb v8, or both a BB v8! There are 3 different crossmembers, & they are all placed differently (frame location) depending on the engine. As far as the bell....the CENTER HOLE SIZE is a yr specific deal. 67 + older are a 4 11/16 " hole(does not matter 3 or 4 spd), wheras the 68 up are a 5 1/8" hole(again 3 or 4 spd does not matter)...... L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-21-2007, 01:24 PM   #5
sixtysevengmc
village idiot
mmmmmmmmmmmkay..............
thanks
