01-21-2007, 10:01 AM | #1 |
Cab Supports - don't delay changing, here's why....
Check out what I found when I pulled my cab yesterday. The cab supports where toast (most are after 39 yrs!) and my truck has average northern rust damage but useable. The front frame mounts looked fine but check out the rears, just a little longer and the cab would have dropped through... There is a lot of moisture trapped by your rubber cab supports so the sooner that you can change the better...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
01-21-2007, 10:21 AM | #2 |
Re: Cab Supports - don't delay changing, here's why....
Wow. I just did mine yesterday, but mine didn't have problems.
01-21-2007, 10:42 AM | #3 |
and your location says Arizona! This was a NY truck for it's entire life...
01-21-2007, 10:25 AM | #4 | |||
Union Electrician
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
01-21-2007, 10:28 AM | #5 |
River life......
Wow!
01-21-2007, 10:28 AM | #6 |
Sierra Grande Club
What’s the best to replace these with? Just another OEM mounts?
Thanks, s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-21-2007, 10:41 AM | #7 |
I'm replacing them with donated mounts...
01-21-2007, 10:28 AM | #8 |
sufficiently talented fool
Holy Rustholes Batman!!!!!!
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
01-21-2007, 10:40 AM | #9 |
I got the complete 4WD set from LMC ($150) does cab, rad and bed... Funny thing is that I only have one other rust spot (besides surface) on the frame and its the mid-crossmember. My truck was undercoated, which you can see gooped up in the photo. I'm getting ready to blast everything, prime then paint.
