Old 01-21-2007, 07:21 PM   #1
gouldie
how do the tail lights ground themselves
like the title says how do the taillights ground themselves. i have voltage going to the bulbs but they still dont work and dont see a ground wire anywhere
i have a 67 c 10
thanks,
chris
67 c10 250 I6 3 on the tree no options
air ride, paint and big block coming within the next 23 years
2001 mustang gt for going fast
gouldie is offline   Reply With Quote
Old 01-21-2007, 07:24 PM   #2
BarryB
BarryB's Avatar
Re: how do the tail lights ground themselves
they ground by the bulb housing's.
BarryB is offline   Reply With Quote
Old 01-21-2007, 07:42 PM   #3
cdowns
cdowns's Avatar
there should also be a ground wire fob the box to the frame// i've always put it from the rear sill of the box to the rear crossmember don't know if thats the factory correct but it grounded good and the lights worked//you could also clean up the back of the reflector where it mounts to body panel to get a gooder ground too
Old 01-21-2007, 09:08 PM   #4
gouldie
thanks for the fast responses. i'll try putting a wire in once i get the chance.
Old 01-22-2007, 04:33 PM   #5
Luvlegs
Luvlegs's Avatar
on my 72, the back of the housing grounds to the inners of the recess - I couldn't get mine to work as the plastic clips kept "easing" back from the housing and the bulb couldn't reach the contacts. As a temporary fix, as I'm moving, I pushed the plastic part against the housing and used the ol' duct tape to hold it tight - worked great - need to replace the ends though.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 01-22-2007, 07:40 PM   #6
cameeks
Long Fleet Club
cameeks's Avatar
I have a question to add to this tail light subject. Why is it that both brake lights shut off when the turn signal is active. I have brake lights without the turn signal on but as soon as I hit left or right they shut off.
Chris Meeks
'69 Chevy Custom/10 Long Bed <-- Thread of the work I did before selling.
Truck is now finished to the new owners design and running around.
I was shown some pictures of the finished product. At least it survived the junk yard.
FAQ Index by Krue Site Vendors Subscribe Here Forum Rules
cameeks is offline   Reply With Quote
Old 01-23-2007, 12:23 AM   #7
basketcase
basketcase's Avatar
This could also be a ground problem. Try running a jumper wire from the light housing to a good clean ground and see if that helps.
Tom
basketcase is offline   Reply With Quote
Old 01-23-2007, 12:28 AM   #8
GREASEMONKEY72
GREASEMONKEY72's Avatar
what about if my hazards are on and i step on the brake they stop flashing, is that normal or what???
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-23-2007, 10:15 AM   #9
cameeks
Long Fleet Club
cameeks's Avatar
Yes my hazards work but I didnt check to see if they go off when I hit the brake. I'll check the ground this weekend. I'm swamped at work.
Also the hazards go off when you hit the brake for saftey reasons.
Chris Meeks
Old 01-23-2007, 01:40 PM   #10
68speedalert
Semi-Senior Member
68speedalert's Avatar
Most likely a bad turn signal switch.
Try to jiggle the t/s lever a little while someone watches the lights to see if they come on, even if a little.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre
'83 Jeep CJ-7, <80,000 miles, original owner
'04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer
'95 GMC K1500 Extended cab
68speedalert is offline   Reply With Quote
Old 01-23-2007, 02:31 PM   #11
cameeks
Long Fleet Club
cameeks's Avatar
I have brake lights without the turn signal on but as soon as I hit left or right they shut off. (Say at night when I have my lights on and I use the left turn signal. The brake lights come on, when I activate the left turn signal the brake lights go off and the only thing active on the rear is the left turn signal (flashing) and the right tail light (solid). Same with the right turn signal. As soon as they go off the tail lights brighten up for the brake lights.
Had to add to it so it is more understanding.
I know that the Cancellation cam is out on the turn switch. And remembering back to when I was doing wiring for hitches and trailers when the ground was bad the parking light would flash oppisite of the turn signal.
I'm just glade that the inspection station didn't catch it last time.
Chris Meeks
Old 01-22-2007, 11:32 PM   #12
jhow66
jhow66's Avatar
Check to see if hazard switch is pushed in. Do harzards work?
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-23-2007, 02:42 PM   #13
68speedalert
Semi-Senior Member
Does the taillight keep working on the side that is flashing?
Old 01-23-2007, 03:30 PM   #14
cameeks
Long Fleet Club
cameeks's Avatar
yes the parking light on the flashing light stays lit also.
Chris Meeks
Old 01-23-2007, 03:32 PM   #15
cameeks
Long Fleet Club
cameeks's Avatar
i have a 67 c 10
thanks,
chris
Did you ever get yours fixed?
Chris Meeks
Old 01-23-2007, 03:37 PM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
cameeks, as indicated, 99% chance, you need a turn signal switch. Your grounds are fin from what you describe.
GREASEMONKEY72, what you describe with the 4 ways stopping when you hit the brakes... that is normal and intended.
Old 01-24-2007, 12:31 AM   #17
gouldie
not yet i've been busy with school and work. i might have some free time tomorrow to try and get them working.
Old 01-27-2007, 12:25 PM   #18
gouldie
alright i just got back from replacing the bulbs and they still do not work. i'm now getting 12 volts when i ground it to the housing and am very confued to why they still aren't working.
any ideas to what could be stopping them from working?
also the part number on the bulb is 2357 i'm not sure if that's the right bulb or not because they're not working
Old 01-28-2007, 10:55 AM   #19
cameeks
Long Fleet Club
cameeks's Avatar
That part # should work. I accidently bout those once for mine and they work fine. They are for the newer vehicles and I was told that they are a diffrent wattage for the computer to detect. I'm not sure on how much of that is true.
Is there any rust between where the bulb socket and housing meet?
Chris Meeks
Old 01-27-2007, 12:33 PM   #20
Aarons72s
Cameeks, On the turn signal switch more than likely the cam is cracked. You can get a new one in the help section at most parts stores. Try this first then if you still loose brake lights then go ahead and do the switch.
Aarons72s is offline   Reply With Quote
Old 01-28-2007, 10:46 AM   #21
cameeks
Long Fleet Club
cameeks's Avatar
I'll look again for a cam. I ask the guys at Autozone about the part when I was there and they said they didnt have it. So I'm going with the more reliable O'reilly's.
Chris Meeks
