Old 01-22-2007, 05:30 PM   #1
entourageguy
Yellow truck club
entourageguy's Avatar
Your thoughts on rear end choices....
Hey guys
Have a chance at two different rear ends to put into my truck when I install the 4 link
1981 firebird 10 bolt 8.5 posi 3.43 with discs
1999 s10 blazer 4x4 posi 3.42 with discs also has sway bar attached
pros / cons
Thanks ..Brian
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 01-22-2007, 05:33 PM   #2
bretcopsey
Re: Your thoughts on rear end choices....
What year Firebird? Second gen should have 8.5" ring gear and I believe 3rd and 4th gen both have 7.5" ring gear.
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 01-22-2007, 06:18 PM   #3
1-ton of fun
polishing a turd
1-ton of fun's Avatar
the firebird one will likely be better, but it depends if it is a 7.5", 8.2" or 8.5"
if you give me an email address, i can send you a chart that shows how to identify it.
1-ton of fun is offline   Reply With Quote
Old 01-22-2007, 07:02 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
I think the blazer 4x4 is almost a direct bolt in and the correct length
Old 01-22-2007, 07:14 PM   #5
SURFER1316
The 99 blazer is a great swap, this is off the top of my head, but will be 59" wide, correct width, believe it's either a 7.625" or 8.5" 10 bolt, either way have stood behind decently built V8 swaps in S10's, and will have the Blazer bigger rear discs that are like 11" rotors
SURFER1316 is offline   Reply With Quote
Old 01-24-2007, 07:52 AM   #6
entourageguy
Yellow truck club
Thanks for the feedback guys. I'm going to go look at the S-10 this weekend.
Brian ...
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 02-07-2007, 10:24 AM   #7
nogaroa4
How did you make out? (entourageguy) I'm looking for a "cheap" rear for my 1955 chevy 1/2 ton. I can't decide. It will be matched up with a sbc (350) and auto trans which will hopefully one day be switched out for a manual trans. What I'm looking for is disc brakes, and a posi. Any suggestions or pointers on where to look?
nogaroa4 is offline   Reply With Quote
Old 02-07-2007, 11:35 AM   #8
Hart_Rod
Hart_Rod's Avatar
I know a lot of folks are using rear ends out of the newer F#$D explorers. They are the correct width, come with disc brakes and posi and are cheap.
Hart_Rod is offline   Reply With Quote
Old 02-07-2007, 05:20 PM   #9
nogaroa4
The explorer defently look like a posiblity. does anyone have any specs on the rear axles currently in are trucks, I belive they are 59" wide, but does anyone know pinion offset? Or who would make an adapter for a chevy to a ford driveshaft?
Old 02-07-2007, 05:40 PM   #10
1-ton of fun
polishing a turd
just have a custom d/s made for that.
i think the explorers have 31-spline axles, people use them as cheap upgrades for mustang (28-spline) rears.
also i don't know if anybody has seen these, but they are good for putting discs on old rears for cheap:
http://www.scarebird.com/
or
http://www.steeltechsolutions.com/RE...PAGE_CODE.html
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
Old 02-07-2007, 10:32 PM   #11
CAL 58 GMC
CAL 58 GMC's Avatar
Hey Brian,
You know where my vote go's to!!!! THE BLAZER!!
CAL 58 GMC is offline   Reply With Quote
Old 02-07-2007, 10:57 PM   #12
jds319
So what year blazer rear ends are good fits? I'm looking for a rear end for my '56 too!!!!
1956 Chevrolet 1500 Task Force
2002 Texas Aggie
Project Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=212633
jds319 is offline   Reply With Quote
Old 02-07-2007, 11:09 PM   #13
CAL 58 GMC
CAL 58 GMC's Avatar
1998 to 2003 Blazers all had rear disc brake. The 4X4 rears are wider then the 2X4's. I used a 2X4 and had to use wheel spacers to get the wheels out more. If I were to do it over again I would us the 4X4.
