01-22-2007, 07:16 PM | #1 |
QJet running rich - Help!
I recently replaced the Quadrajet 4bbl on my truck with a newly rebuilt one. It came all painted up, looked better than a new one. It was suppose to have a new choke, new float, leaking ports all epoxied up, etc., I guess you could say the typical rebuild. The replacement carb made a big difference in the way my truck runs (much better). I had to adjust the idle mixture, it was off quite a bit. The only thing now is it seems like it is running real rich. I'm basing this on the fact that it smells rich. I can open the door and you can smell the gas. If I walk back toward the exhaust pipe, I smell like I've been taking a bath in gasoline. The truck is a little rough until it warms up, but it runs real good after that, but still I get the rich smell. I don't think this is normal is it? Is there anything else I can check to determine why is smells so rich? Am I going to have to go into the carb and adjust the float level or something (Lord I hope not). Any ideas you guys could throw at me would be much appreciated.
2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
01-22-2007, 07:54 PM | #2 |
Msgt USAF Ret
Re: QJet running rich - Help!
This is written by an expert on Q-jets.
http://www.lbfun.com/Corvette/Tech/v...ng%20Paper.pdf
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-22-2007, 08:02 PM | #3 |
Semi-Senior Member
Did you adjust the idle mixture this way?
http://67-72chevytrucks.com/vboard/s...d.php?t=224096 Otherwise, where did the 'rebuilt' unit come from? A float set too high will make it idle rich. Is the choke wide open after it's completely warm?
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
01-22-2007, 08:55 PM | #4 | |
01-22-2007, 09:42 PM | #5 |
Have you pulled a plug to look for carbon? Do you see any black smoke at any point? Have you thoroughly checked for leaks in the fuel line?
>> I actually had a Q-Jet once that would have a float valve stick open occasionally and gas would overflow out the vent.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
01-22-2007, 09:53 PM | #6 |
laying low
Could it be after having driven these late model fuel injected vehicles for a while your truck smells rich because it is more so than the newer ones? The newer ones run much much leaner. The older carb'd ones do smell of gas naturally. If the spark plugs are blackened up then it probably is in need of some carb adjustment. My 97's exhaust smell clean compared to my 69 and it is a fresh build.
01-22-2007, 10:04 PM | #7 | |
01-22-2007, 09:55 PM | #8 |
No, I haven't pulled the plugs yet. I was going to do that this weekend and replace if necessary. There is no black smoke from the exhaust at all that I can tell, though the end of the exhaust pipe is black. Haven't checked for fuel line leaks...what would this do other than cause mileage to go way down? But, anyway, I haven't noticed any leaks, but have not thoroughly gone over the lines. No leaks from the carb itself, clean as a whistle.
01-22-2007, 11:29 PM | #9 |
How many turns out from closed are the needles?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
01-22-2007, 11:58 PM | #10 |
I honestly don't remember. If I had to guestimate, I'd say around 4 turns out, but that's just guessing. Seems like I've been loosing memory cells at a rapid pace here lately. I do think I'll start from scratch again with the mixture screws by turning them both back in and then back them out about 2 1/2 to 3 turns and then re-check the mixture keeping up with how much I have to turn them. At least I'll know then.
01-23-2007, 02:32 AM | #11 |
Semi-Senior Member
Run them out until your vacuum peaks. Then, slowly, by 1/4 turns, turn them back in, alternately, until the vacuum just drops. You'll also hear the RPM's drop a little. Open the screws back out about a 1/4 or so (so vacuum & erngine smooths out).
If you didn't turn them back in, you are running rich. BTW, don't pull all the plugs, just a couple easy ones. I would reajust the mixture like I described before that. Also , look down the throat of the barrels and check for ANY visible fuel dripping from ANYWHERE, with the engine running and warmed up, at base idle.
01-23-2007, 02:56 AM | #12 | |
>>Check a plug or two as mentioned above for sooty residue which indicates rich mixture.
01-23-2007, 12:48 PM | #13 |
Ok, thanks for the suggestions. I'll do all of this and then post back the results.
01-23-2007, 12:55 PM | #14 |
You might want to verify the choke is set up correctly.....
Rudy Fierros '95 Honda VFR750F Used to have a '71 Chevy Stepside, Guards Red, Lowered 4" rear, 3" front, White Oak bed wood, 700R4 w/373 gears until some low life stole it! |
01-23-2007, 01:38 PM | #15 |
Check the float level. It may be stuck open. Sometimes crud from the tank gets through the filter and messes with the float.
72 C2500 LWB 402 Sierra Grande 05 Odyssey 08 Tundra |
03-08-2007, 12:34 PM | #16 |
I bought a rebuilt Q-jet from O'Reilley a couple of months ago. It smelled gassy after the first week, I never had to choke or pump to start it cold. I took the carb apart and the "epoxy" on the bowl ports crumbled apart. It had the consistency of feta cheese. I put JB weld on, thet fixed the leaks, bit I'm still not happy with it. I can't get enough vacuum to open the secondaries. I'm gonna clean up my 600 Holley and see how long I can make it run before the float needles stick open and it dumps gas.
1970 CST-10 owned it 26 years, finally back on the road after a 10 year rest. 1989 Suburban 1971 Sleekcraft 455Olds Berkeley 1992 SC400 pimp ricer |
03-08-2007, 12:56 PM | #17 | |
Semi-Senior Member
If you want to see them open you're gonna have to have someone braketorgue it while you watch the flaps on the secondaries. Generally, that's not a great idea, for safety reasons. I can tell if they're opening by the sound of all that air sucking in when I floor it while driving. You can compare how it sounds without the sec. by flooring it with the engine cold, (because the choke is closed). The choke has a sec lock-out that keeps the sec from coming on until it's wide open. BTW, the Holley 600 is the carb that turned me against Holleys. As a rule, never buy a rebuilt carb from a parts store.....fix what you got.
