01-22-2007, 10:54 PM | #1 |
Sierra Grande Club
best intake for torque.
Now that I have my engine out I was able to get a good look at the intake, it’s an Elderbrock Street Dominator.
I’m wanting something that will give me the most benefit in the low to mid range, mainly torque. What seems to work with the Quadra jet Carbs? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-22-2007, 10:58 PM | #2 |
fugedaboutit
Re: best intake for torque.
That intake should work great for lowend.. dual plain right?
Currently truckless |
01-22-2007, 11:29 PM | #3 |
Sierra Grande Club
Is not a dual plane, it just opens up straight in.
01-22-2007, 11:44 PM | #4 |
fugedaboutit
Ok my bad, I was thinking of the holley street dominator- Its a dual plane. I think a dual plain is your best bet. just my .02. Good luck with your build!
01-22-2007, 11:54 PM | #5 |
I used the Offenhauser 360 on my 355 with a square bore Holley but it isn't the Dual Port. The catalog claims good off idle to 6000 . That seems rather optimistic but Weiand claims the same for it's Stealth. We will see next summer.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
01-22-2007, 11:07 PM | #6 |
GEARHEAD
I've built 38 different small block if you can try to match everything cam heads intake carb to get the best benifit. but if you can't go that far maybe just cam and intake. but any way a real good choice is the edlelbrock air gar
edl-7501 or polised edl-75011 you street domiator is ok also but isn't it made by holley Last edited by RACINJASON22; 01-22-2007 at 11:11 PM. Reason: forgot to say |
01-22-2007, 11:14 PM | #7 |
just remember a quadrajet is a spreadbore flange...
if you buy a new one get one that mounts with the carb you plan to run. edelbrock and holley are squrebore flange.. |
01-22-2007, 11:40 PM | #8 | |
Sierra Grande Club
s/t
01-22-2007, 11:20 PM | #9 |
Dual plane, low rise - take yer pick
01-22-2007, 11:34 PM | #10 |
GEARHEAD
oooooppps fogot about the bolt pattern I'm almost positive they make a muti fit I check for the # 7501 & 75011 are not right thanks for the correction rage'nrat638
EDL-2601 DUAL PATTERN Last edited by RACINJASON22; 01-22-2007 at 11:42 PM. Reason: RIGHT PART # |
01-23-2007, 08:29 AM | #11 |
heres edlebrocks dual plane,, dual flange intake (one intake does it all)
INTAKE LINK you can mount any carb squrebore or spreadbore and not be limited to one carb..0-5000 rpm range TO INSTALL A SQUREBORE..just use pictured plate Last edited by rage'nrat638; 07-12-2007 at 06:58 AM. |
01-22-2007, 11:38 PM | #12 |
If you are building a low end torque engine you can't beat a stock iron manifold. Of the tests that I have seen between the stock manifold and various after market street dual planes the stocker held it's own and in some cases posted higher torque numbers up to about the 3500-4000 rpm range. Hot Rod Magazine did a test a few years ago between the stocker, Performer and Performer RPM. All 3 were virtually a dead heat up to 3500 then the stocker fell off a little in the mid range. Of course the Edelbrocks posted better HP numbers in the upper mid to top end range. Installed with a Q-Jet on a torque engine that would rarely see the top side of 4500 you would get very good results with a stocker. GM made some aluminum versions in the '80s that take a Q-Jet too if you want the look of aluminum. I have one out in the shop if you would like to see what it looks like. I put on an Offenhauser I also had since I'm using a stronger cam and ported heads and decided not to use it.
01-22-2007, 11:40 PM | #13 |
blood type; Retumbo
what about the Offenhauser dual port 360? I thought some one here had one.
another one that I had exceptional results from is the Stealth from Weiand. and it was about $5 cheaper than Edelbrock's performer. Last edited by 68C15; 01-22-2007 at 11:44 PM. Reason: coco puffs taste great at bed time |
01-22-2007, 11:51 PM | #14 |
GEARHEAD
If you are thinking about up grading later on check out some of the pre-made kits available from holly edelbrock you pick then go with the intake frome that kit you will spend a little more in the long run by not buying in a package but I for one know how hard it is to come up with all of the money at once. Later when money allows you can buy the other pieces of the package.
by the way that part# is edl-2601 spread bore and square flange so you can even upgrade carb a a later time |
01-23-2007, 05:32 AM | #15 |
I second the stock intake comment...
money would be better spent on cam, carb, or gears. rather than replace a perfectly fine stock quadrajet intake, with a $100.00 version with the same results. My thoughts are; to improve torque, change cams... to improve seat of the pants "feeling" of torque, change rearend gears... My .02 cents...
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 01-23-2007 at 05:33 AM. |
01-23-2007, 07:29 AM | #16 |
68 C10 Longbed
There are lots a good intakes out there for torque as mentioned above. I personally have had very good luck with the edelbrock performer on small blocks and Weiand Stealth on Big blocks. Don't put on too large of a carb. and you'll have great torque and good throttle response. Just my .02
01-23-2007, 08:11 AM | #17 |
Sierra Grande Club
Maybe I should just keep the Eld. Street Dominator? Does anyone know how it should perform? It sounds like the performer duel plane will give me torque & mid to hi RPMs. I’ve also been looking at the holly fuel injected units as a package deal. They look good. I wonder if you can data log with those units to tune on the fly using an o2 sensor?
s/t
01-23-2007, 10:46 AM | #18 |
I would say performer intake for sure with a mild cam and a small vac secondary carb (600-650 size). If money is an issue then the dual plane stock intake, it is easier to change out later on too if you want to go the aluminum route.
I think they make a performer rpm intake spread bore version just not in the air gap type. |
01-23-2007, 11:14 AM | #19 |
GEARHEAD
Right on rage'nrat. The air gap # is EDL-2601 in square/spreadbore duel patternhttp://store.summitracing.com/partde...5&autoview=sku
Claimes Idle to 5500 very responsive. Plus the air gap keeps the carb cooler plus I love the way they look Single plane look Dual plane power!!! |
01-23-2007, 02:16 PM | #20 | |
Do they make a spread bore Performer Air Gap for a BB Chevy? |
01-23-2007, 03:16 PM | #21 |
GEARHEAD
Sorry guys no spead bore for the big block sqare bore with a plate will work see pics part # summit edl-7561 and sum-g1401
01-23-2007, 03:24 PM | #22 |
GEARHEAD
edl-75611 for the ones that think that it makes them faster!
01-23-2007, 11:58 AM | #23 |
Does this count as an 'intake'?
Richard 1970 Chevy (growing pile of parts) 2003 Silverado SS |
01-23-2007, 12:52 PM | #24 |
George Morgan Hernando, MS '69 C-10 swb fleetside '72 GMC swb Stepside |
01-23-2007, 12:00 PM | #25 | |
Sierra Grande Club
Are there any problems with the air gap intakes in the cold? s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. Last edited by Sport/Truck; 01-23-2007 at 12:02 PM. |
