01-25-2007, 02:28 AM | #1 |
Has anyone done this??
My friend just converted his 69 c-10 to leaf spring, and my question is would it be difficult to put the crossmember and trailing arms in my 2wd 79 blazer. Any help would be appreciated..
01-25-2007, 09:42 AM | #2 |
its just $$$$$
Re: Has anyone done this??
probably be alot of work.....but im not sure.
01-25-2007, 10:19 AM | #3 |
A guy with a truck
Shouldn't be too much trouble. The frames are the same width, I'm pretty sure. I just did this with a '72 4wd Blazer. Set everything in place at ride height, square it up, drill holes and bolt in. You will have to fab an upper spring/bag mount because your rear framerails don't 'flare' out to accomodate them.
I have a build thread I need to update in the Blazer section you can look at for ideas. -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-25-2007, 11:13 AM | #4 |
The frames are quite a bit different from 67-79 but it could work. You will have to make your own front crossmember and fab up a spring bracket for the rear. I would also get a rear end out the 69, so the trailing arms will bolt to it, otherwise it will require even more fab work on the rearend
01-25-2007, 11:26 AM | #5 |
Señor Member
What's your real objective in doing this? If it's to get this type of suspension geometry, in this case, I'd recommend buying an aftermarket multi-link suspension. There is probably more work to get the '69 suspension in place than using one of the many available "custom" kits for your year model.
01-25-2007, 01:55 PM | #6 |
I would like to try this since it would cost me nothing for the parts and I can get the rear end from him pretty cheap. It will have air ride.
