01-25-2007, 05:50 PM | #1 |
nothing to do with our trucks
My buddy threw a rod in his 98 cherokee 4.0L HO. This weekend i am helping him put a new engine in, nothing special just a replacement crate motor. Now I've never done a fuel injected engine swap and I am wondering if there is anything i should know??? Im scared of getting the motor in and then having an electical nightmare with it not starting. any adivce is appreciated.
Thanks, Travis |
01-25-2007, 09:07 PM | #2 |
Re: nothing to do with our trucks
most important thing....
Label EVERYTHING as you remove it!!! otherwise it should be a straightforward swap.
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
01-25-2007, 09:18 PM | #3 |
Sierra Grande Club
There’s going to be some adjustable sensors that you will want to avoid moving… the throttle position sensor. you will most likely be swapping the intake over so shouldn’t be an issue. You are going to have to transfer the cam angle sensor if it has one. If it does you will need to put it at about the same position. You will adjust that when you set the timing.
That’s all I can think of now. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-25-2007, 09:35 PM | #4 |
Sierra Grande Club
One word of caution- The fuel line will be under some pressure. So don’t get in a hurry and get fuel in you eyes. I don’t think you’ll have any problems. But if you do just Google whatever you have trouble with there’s tons of info on those. They seem quite popular and the info should be abundant.
Good luck. s/t
01-25-2007, 09:43 PM | #5 |
Go to pirate4x4.com and go in there jeep section for newbies and ask away with your questions there. Now i will tell you those 4.0's are a pain in the butt to pull out. Ive done it once.... So you know. leave the tranny and t-case in the jeep.
Good Luck. |
