Old 04-24-2002, 10:00 PM   #1
shortbed70
shortbed70's Avatar
Post dragging mufflers
I,ve got a problem see they decided to put this speed bump in my court that is I swear 8 inches tall and my high $$ flowmasters are dragging. Ive got a 4/6 drop and going to raise it 1 inch all around but I was wondering how you could run the mufflers with plenty of ground clerance. I'm running manifolds not headers and they dump in front of the axle. suggestions please
1970 shortbed(project)
350/350 dropped 4/6 21/2" flowmasters.Plans for bigblock or just a little stroker.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-24-2002, 10:14 PM   #2
cableguy0
Post
try layin em flat if they arent already
72 chevy lwb 350 lunati cam ported and polished cast 2.02 heads proform hei edelbrock performer rpm and 750 carb balanced bottom end 9.5:1 compression ps,pb th350 with a tci 2500 stall convertor full man v-body kevlar clutches and bands as well as other goodies
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-24-2002, 10:17 PM   #3
shortbed70
shortbed70's Avatar
Post
They are flat but they are 3" thick plus 1/2" clearance between frame.
Troy
Big Red Dog build
Old 04-25-2002, 12:11 AM   #4
lost wages
lost wages's Avatar
Post
flowmaster just came out with a new series that are thinner for vehicles that have clearance problems. ill be selling mine to get these.
68 swb fleet soon to be bagged and big block powered
68 lwb fleet in primer
35 chevy truck
97 dodge on 35 boggers
3 out of 4 aint bad!
Jefferson city, MO
lost wages is offline   Reply With Quote
Old 04-25-2002, 07:01 AM   #5
fast_dev
fast_dev's Avatar
Post
how much for yours??? i have mine up under the box in front of the rear but mine exit at the rear bumper.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112
67 nova numbers matching 327 4 speed 13.6 @ 102mph
70 longhorn c-30 402/4 speed
70 c-10 swb 402, muncie 4 speed
94 s-10 350/th350 3:73 posi
71 c-20 402/th400 towrig for racetruck.
72 4wd lifted on 35's
72 350/3 speed winter beater
fast_dev is offline   Reply With Quote
Old 04-25-2002, 10:42 AM   #6
70 Jimmy
aka Crusher, Crushergmc
70 Jimmy's Avatar
Post
There is a company that make thin mufflers for hotrods. Try doing a search on "thin mufflers" , or maybe "hotrod mufflers"
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
"It's funny till someone gets hurt, then it's freakin' hilarious"
70 Jimmy is offline   Reply With Quote
Old 04-25-2002, 10:49 AM   #7
70 Jimmy
70 Jimmy's Avatar
Post
Try this www.spintechmufflers.com/spintech/spintechindex.asp
"KEEP IT DOWN!"
70 Jimmy 454 2wd
56 GMC Big Window
Old 04-25-2002, 11:24 AM   #8
Hutch
Hutch's Avatar
Post
Check this link and look under the 68 restoration link.
They have cut holes into crossmember which have the trailing arms and carrier bearing attached to it.
They have also made some other nice mods on the rodstoration of this clean early truck.
I was considering this mod while I had mine apart but since it will ride at stock height I am not sure whether there would be a benefit from this or the one piece shaft mod.
When it comes time for mufflers you can be sure that whoever installs them will route them correctly instead of bending the sheet metal on the back of the cab. Both of my trucks have had this done during their lives.
http://www.earlyclassic.com/
John Hutchison
Grapevine,Texas
76051
71 1/2 ton swb 307 pg
69 Jaguar XK-E 4.2 Roadster
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
