Old 01-26-2007, 06:21 PM   #1
1LIME69
1LIME69's Avatar
72 K5 gas tank
I have a 72 K5 that needs a new gas tank was wondering where was the cheapest place to get one and which do I need (steel or poly). Also do I need to get a new sending unit and straps or will my stock one do the job?
1LIME69 is offline   Reply With Quote
Old 01-27-2007, 12:29 AM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Re: 72 K5 gas tank
Ebay has them. All the board venders have them too. All priced pretty close. They do come with straps but if your old ones are good, just use them as the fit is much better. Mine came with the sending unit and lock nut. The filler neck will need to be modified or you need to find a rubber hose that will fit. You will see what i'm talking about when you get your tank.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 01-27-2007, 09:46 AM   #3
bigdon-70blazer
Re: 72 K5 gas tank
Let me ask this, I have been planning on replaceing mine because it is 1. old and may be somewhat rusty on inside and 2. has a very slight leak from a dent or rock that abraded it and someone attempted a repair but when I started disassembling the blazer last year, I noted that that area was still wet looking, not streaming out but wet. PO welded a small patch in the corner. With all the fitment issues I.m reading, would it be better to repair tis one or is it possible? Thanks
bigdon-70blazer is offline   Reply With Quote
Old 01-27-2007, 02:01 PM   #4
jaros44sr
jaros44sr's Avatar
Re: 72 K5 gas tank
Most things in auto related topics I will attempt, this does not include repair of fuel tanks, big bang theory.
You might try to look inside your fuel tank by removing the sending unit, then you could add a tank sealant if it is rusty.
Someone on the board wrote a very good thread on the topic of tank replacement and his troubles. Most of the problem was due to the fitment of the filler neck. Straps are another issue, save yours if you can.
Good luck guys, I'm sure some other guys will have opinions. Just my .02
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-27-2007, 02:50 PM   #5
pound41
Re: 72 K5 gas tank
You can have a tank recoated on the inside it is supposed to be very effective. A friend had to do that for a Tbird that had no repo available.
pound41 is offline   Reply With Quote
Old 01-27-2007, 10:30 PM   #6
oilyrag80
oilyrag80's Avatar
Re: 72 K5 gas tank
Just buy a new steel tank then take both tanks to a raditior shop and have them solder the old neck on the new tank simple and cheap
oilyrag80 is offline   Reply With Quote
Old 01-31-2007, 08:56 PM   #7
meathead95
computer illiterate
meathead95's Avatar
Re: 72 K5 gas tank
take it to a radiator shop and they will clean and coat it, and can probably fix the leak for you. if it is leaking from a SMALL puncture i would fix it. if it is leaking from rust i would replace it.
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 02-03-2007, 02:00 AM   #8
krue
Designated A-hole!
krue's Avatar
Re: 72 K5 gas tank
This thread is not a wtb, if you have something to sell please subscribe and post it on the parts board.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 02-03-2007, 12:45 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: 72 K5 gas tank
I have one of each, the 4wd has a poly, the 2wd steel, I like the steel
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 02-03-2007, 12:57 PM   #10
65-72 chevytoys
65-72 chevytoys's Avatar
Re: 72 K5 gas tank
Mine is poly I don't have to worry about it rusting ever again.
2004 Chevy Silverado 1500LS SWB 5.3L
2004 Corvette Z16 #770
Wish I had not sold 72 blazer
65-72 chevytoys is offline   Reply With Quote
Old 02-23-2007, 09:54 PM   #11
albertarose
albertarose's Avatar
Re: 72 K5 gas tank
did you install the poly tank youself? any links for this? saw the one for th steel one..but brackets are l shaped for my poly kit..thanks..leon
albertarose is offline   Reply With Quote
Old 02-23-2007, 11:08 PM   #12
pumpkin
pumpkin's Avatar
Re: 72 K5 gas tank
I built my own tank, 50 gallons it hurts to fill it, but when I'm out wheeling I know I'll make it home.
pumpkin is offline   Reply With Quote
Old 02-27-2007, 08:58 PM   #13
Idaho Outlaw
Idaho Outlaw's Avatar
Re: 72 K5 gas tank
Where did you fit a 50 gal tank?
1972 Chevy LWB K10 Custom/Deluxe
Earth first! We'll log the other planet's later.
Idaho Outlaw is offline   Reply With Quote
Old 02-27-2007, 09:15 PM   #14
albertarose
Re: 72 K5 gas tank
I bought mine on ebay the poly kit .. they are about 200.00 give or take...brothers has the same one listed comes with sender and straps etc and mounts under rear frame rails..
Old 02-28-2007, 09:25 AM   #15
BUDDY
Global warming is a myth
BUDDY's Avatar
Talking Re: 72 K5 gas tank
Yeah, & where are the pictures/dimensions for us to copy it?
Later,
Buddy
Henderson, NV
1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!!
1990 K5 with 37's
2003 Discovery SE7 - Wife's
BUDDY is offline   Reply With Quote
