Can't ReMember
carrier bearing
Should I be able to push up the drive shaft up a half inch inside the carrier bearing or should this be solid inside the hanger? I always thought it was solid. Was going to go trailer a 72 GMC back from Geogia tommorrow. Was just looking at this.
Adversity doesn't test your character; it reveals it. 71 C-10 LWB 350/TH350. I purchased it in 1978 for $1400. I'm currently abusing it daily. (when it's running ![]() |
Can't ReMember
Re: carrier bearing
While I was getting things ready for the Georgia trip, I sent the wife to Advanced Auto Parts to get the carrier bearing. I called first and she said they had one. She comes home with a computer printout with all the correct info, but the wrong carrier bearing. Now the place is closed and I'm screwed. Could someone go out and rattle the drive shaft at the carrier bearing and see if it moves 1/2 inch or so. I would really appreciate it.
Thank you
Sierra Grande Club
Re: carrier bearing
I not 100% on this but on a car I just sold had 2 carrier bearings and it was basically a rubber mount that allowed some movement. Are you getting any vibration now?
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Re: carrier bearing
the carrier bearing is pressed on the drive shaft yoke..
there are a few different types a tear drop and a u shaped are the most used types. the bearing is mounted in rubber and moves very hard up and down, if it's floppy it's shot ![]() |
#5 | ||
Can't ReMember
Re: carrier bearing
![]() Quote:
Thanks for your help, guys.
Can't ReMember
Re: carrier bearing
I hope everyone is having a good day. Thanks for reading my thread and helping out if you can. Got the correct carrier bearing this morning. I have the driveshaft off. Is there anyway to tell if the universals are bad? If you grab the drivshaft and twist back and forth by the universal, should there be any movement at all? I really enjoy doing my own work, but I'm not very knowledgeable. Just the basics can be a challenge. I might have road the short bus in an earlier stage of my life.
![]() ![]() Any help would be appreciated. Anybody that needs pic, let me know.
Re: carrier bearing
move the u-joints around and if they move smoothly then they are fine but if they feel grittey or stuck then they are bad so look for smooth free movement and the carrier will move around a bit since its rubber mounted about a 1/2 inch or so
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME Last edited by GREASEMONKEY72; 01-27-2007 at 12:48 PM. |
