![]() Join Date: Jan 2007
Quality aftermarket bedsides
Can anyone tell me about the quality of the aftermarket beds. The originals seem to have fallin of the earth. oldno7
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am. ![]() |
Re: Quality aftermarket bedsides
Goodmark short wide fleet are very nice. Great fit and very well made. The don't make a long bed, and I have never used the step side.
try lmctruck.com
Yah the good mark ones are great! I put one on a 67 in 03. Here is a pick of 1. The bondo is from me welding in the marker light and filling the stake pockets was straight until I welded it! The only mod was a slight trim on the front bottom inner. Like a 1/8 had to cut off the bolt strip.
Hey thanks for the pics, Looks pretty good. What are you putting the bed on? What project that is! I've heard good and bad about different sheet metal dist. I think the thicker gauge metal the better. Thier's a place in Indy or a Dist. I think he goes by GMC Pauls or something, he says he will only sell quality parts. It may be worth the drive after a little research. When you welded in your side marker lites, did you kinda spot weld them or bead weld them? It sounds like you may have gotten the metal to hot. It still looks good though. Wish I had a short fleet. oldno7
I am a Referee of life.
oldno7, there are a lot of site supporting vendors.Almost all will have better pricing than LMC.Almost all offer discounts to BB members.Almost all go to swap meets and shows and may bring what you need to a show saving you drive time and shipping.Use the BB vendors whenever possible.Most of them build trucks also and will make the smart move of only using the best quality parts available.Almost everyone knows it's cheaper to start with good stuff than to repair tweak it to make it right.
That's my 2 cents./
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
I welded it spot style on the lowest setting and had wet rags around it to try and keep the warping to a minuim but it still warped. Not real bad as the bondo is real thin. I just posted a build thread for this truck. I built it in 2003. Yah gmcpauls has that policy if you go on his web site. He even stopped carrying some parts do to they were junk. The major difference in sheet metal will be noticed in rockers. Some are just pathetic shredder food while others are thicker and heavier to original.
LAIDOUT
I went the same route as Aaron. The stock bedsides on the short bed I picked up were from some kind of Bondo experiment gone bad. I bought two aftermarket bedsides. I too got some warping welding in one of my markers, even though I though I was going slow enough. One the second one I spot welded about 4 times then took a ten minute break each time, much better.
I think the quality is fairly good, but even if you weren't shaving the markers and stake pockets you may need to fix a few areas to make it perfect. I don't intend to run tail light trim so I had to fix the thin strip of metal to the inside of the tail lights [the area in yellow in the pict], it had some wrinkles. |
That bedside looks to be perfect to me. Is that painted or primer? If it's primer the paint is going to rock! How would I go about finding these site supporting vendors. I'm kinda new here, and not quite sure how to get around the site yet. It's nice to see and get information that's for sure! If you could send a picture of that bedside on your truck I sure would like to see it. Everybody love pictures I'm just getting started oldno7
#10 | |
LAIDOUT
![]() Added; unfortunately that bedside is still not installed. I plan to get the cab reinstalled and the front clip back on before I assemble the bed. Plus, the bed is much easier for me to store in pieces than it is assembled because I am working in a 2 stall garage. Last edited by BigSky71; 01-29-2007 at 01:53 AM. |
#11 | |
Good luck with your build, and rest assured, if you have a question, it can be answered on this site. ![]()
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
