01-31-2007, 08:51 PM | #1 |
Alternaters: Don't buy rebuilt!!!!
OK....I have now replaced my alternater for the 4th time in 5 years. Sure you get a free replacement for the 100 bucks you spent, but they are crap parts. So this time I spent the extra dough and bought a brand new Delco- Remmy. You know the ones that go 8+ years without any problems?!?! I hope this one goes much longer than the last 4 combined....8 volts after 11 months is just plain unexceptable. The one before it had 12 volts after 4 months. Thanks alot NAPA!!! I'm staying with Carquest and AC Delco for now on.
OK RANT OVER WITH |
01-31-2007, 09:58 PM | #2 |
its all about the +6 inches
Re: Alternaters: Don't buy rebuilt!!!!
NAPA has junk alt, starters, and batterys. If your NAPA offers wilson brand reman'd starters and altenators, then they are worth buying... but not there normal ones, they totally suck.
01-31-2007, 10:17 PM | #3 |
Designated A-hole!
You're waaaayyy better off (IMO) to go to a reputable auto electric shop and have your alternator rebuilt. Costs less than half of a "rebuilt" alt from a parts store and I've not worn one out yet.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
01-31-2007, 11:08 PM | #4 |
I agree. Never had a problem with the place I take my alternators/starters to. iluvmy72 problem sounds more like a wiring problem that's causing the alternator to burn out quickly than the rebuilds them self. That or you're using a dead battery and trying to get your alternator to charge it.
01-31-2007, 10:42 PM | #5 |
Sierra Grande Club
Here’s my take. Don’t buy rebuilt, but having yours rebuilt instead is ok. Or New always works too.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-31-2007, 10:46 PM | #6 |
~Rest In Peace~
rebuild it yourself parts are cheap
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
01-31-2007, 11:14 PM | #7 |
laying low
Reman'd alternators from any parts store or reman'd alternators from a local alt shop can give you trouble if they do not use the best of parts. Thing is most everybody these days are looking for the cheap price and expecting the best service. All parts stores and alt shops are offering the cheap stuff cause it sells better and have the upper grade if you ask for it.
Also worth pointing out is some guys use alternators with too small an amp output to keep up with the power demand of the vehicle and all the extras, radio, amps, air pumps, etc. Too much demand on a small output alt will definately shorten the life of it.
02-01-2007, 01:32 AM | #8 | |
Semi-Senior Member
NAPA premium is all I want to put on.
'68 50th Anniversery LWB Custom Fleetside, '77 305 v-8, turbo 350, factory speed alert (still works), '71 drivetrain w/front discs. Some call it ugly yellow, others call it Ochre '83 Jeep CJ-7, <80,000 miles, original owner '04 Chevy Suburban, 4x4, 2500, 6.0 ltr, Predator Diablo programmer '95 GMC K1500 Extended cab |
01-31-2007, 11:30 PM | #9 |
Great.... I just bought an alternator from NAPA.
Should've checked with you guys first.
The Fastor Pastor '68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed: '70 swb; TH-400 - bagged & shaved. Looking for new engine or parts. Wife - Original {A Real Classic!} |
01-31-2007, 11:56 PM | #10 |
Real Projects never die
just pulled the alternator off my dads truck a 170k miles on his 1973 3/4 ton. Then again it wast the heaviest truck you could orer (special heavy duty front and rear). And tis been treated like a show truck for the last 140k miles of its life. Even though its body makes it look like a junker, its one hell of an old work truck.
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
02-01-2007, 01:11 AM | #11 |
I've never had trouble with reman alts from advance auto parts live time warranty i have had one on my f-150 for about 3 years no problems i have a reman with internal reg on my 71 no troubles. but thats what the life time warranty is for never buy from autozone
02-01-2007, 06:55 AM | #12 |
I use alternatiors and starters from oreillys. They have 3 grades a cheap line, a good rebuilt line and new line. I only use the good line and havent had any problems with there starters or alternators. Just my experiance.
02-01-2007, 10:54 AM | #13 |
luckily, these alternators are easy to replace if you do cheap out like me and buy the budget alternators. it's a bit more of an issue when you have to pull fan and radiator to get at a v6 honda alt (which was one of the only american parts on the engine, and coincidentally the only part to wear out at 50k)
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration. |
02-01-2007, 11:40 AM | #14 |
I have bought loads of parts through the years from O'reillys with nary a problem. I will NOT buy anything from Autozone!
02-01-2007, 12:30 PM | #15 |
It's a scam,the lifetime warranty at AZ. I got suckered into thinking they must be real good units to have that LT warrantee,but it's just the opposite apparently.The things are so cheap they can afford to replace them 4 or 5 times and still make money.
>>Auto Zone is a good place to by oil and hand cleaner.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
