Old 08-26-2002, 10:34 PM   #1
old_truck1969
old_truck1969's Avatar
tail light problem
I had the 4 way flashers going on my '86 today. When i got around to the back of the truck, i realized that the drivers side tailight was out. No problem, i figured, easy fix. I took the old bulb out and put the new one in. When it came time to test, it didn't work. No brake light, signal light, or running lights worked on the driver side. When i put the signal on in the truck, the turn signal still flashed inside the truck. The front signal light on the driver side still flashed. I thought that if a bulb was burnt out anywhere, the signal would remain solid in the cab. Anyone have any ideas?
"All Corvettes are red. The rest are mistakes." - John Heinricy
old_truck1969 is offline   Reply With Quote
Old 08-27-2002, 07:49 PM   #2
Zkast
Zkast's Avatar
Check the ground wire for that socket. Start by testing inside the socket and work your way to the actual ground on the frame. Tug on the wires also, its common to have a broken/corroded wire inside the insulation and never see it.
If the bulb is good and the ground is bad, the other bulb will flash semi normaly because its pulling resistance from the parking light circuit. (inside the bulb)
Zkast is offline   Reply With Quote
Old 08-27-2002, 11:16 PM   #3
crossy
Oh,you can't buy that new
crossy's Avatar
tailight
usually related to some cheezy wiring tap ins underneath where some one years ago tapped into the wires for a trailer wiring plug. do a good continuity or 'Pull ' test. DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
84,C10 SWB-Yella,stock
86 K10 SWB-Red, hopped up 305,4/S
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 08-31-2002, 12:53 PM   #4
old_truck1969
thanks crossy, it was the hack job of a trailer harness that was underneath the truck
