Old 02-06-2007, 08:39 AM   #1
unreconstructed1
nec absolutum
unreconstructed1's Avatar
later model frame for a 67 gmc
hey ya'll, I just got a new 67 GMC project vehicle. manual steering, manual brakes, straight 6, 3 on the tree. I want to convert it to power steering/power brakes and put a bigger engine in it. my question : would it be easier to just put a later model frame underneath it theat has all the power steering and brakes, or would it be easier just to install each seperately? Im used to building camaros, so i dont know too much about these trucks, thought i'd give it a try. thanks for the help.
unreconstructed1 is offline   Reply With Quote
Old 02-06-2007, 09:04 AM   #2
RicksTrucks
RicksTrucks's Avatar
Re: later model frame for a 67 gmc
Using the existing frame: 1) frame would have to have the dimple for the power steering box, 2) power brakes just sits on the firewall, 3) would need V8 engine perches. The last two are pretty easy. If the frame doesn't have the dimple, some have made one with a hammer. Only advantage to going to an older frame would be a 71-72 and get front disc brakes.
68 Short Stepside C-10
69 SWB C-10
70 Flatbed C-20
70 LWB C-20 BB402
70 LWB C-10 CST
70 LWB C-10 CST
71 Short Stepside Cheyenne C-10
72 LWB C-10
72 Blazer 4x4 4spd
95 Jeep Cherokee 4x4
RicksTrucks is offline   Reply With Quote
Old 02-06-2007, 09:36 AM   #3
cooters
to change the whole frame would be way to much unneeded work, change the front crossmember to a 73-87 truck and most of the swap is complete
cooters is offline   Reply With Quote
Old 02-06-2007, 09:51 AM   #4
If you are tearing it down anyway,then using a later frame is a good idea.Especially if you can find one that has everything the way you want it already...rebuilt,lowered,crossmembers/mounts,etc.Maybe even the drivetrain you want.A beat V8/auto,p/s,p/db,longbed is an easy find.Your little`67 GMC is kinda rare.
BTW,Welcome to the message board!
Old 02-06-2007, 02:14 PM   #5
Americanrider
Welcome, PS & PB mods are easy since you already have a working knowledge of GM stuff. Stuffing a V8 in there is super easy. Whatever mods you can think of it's been done already or could be figured out by board members. Post somemore details and pics of your new toy.
Americanrider is offline   Reply With Quote
Old 02-06-2007, 02:32 PM   #6
truckdude239
truckdude239's Avatar
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 02-06-2007, 05:06 PM   #7
Okie Bucket
I agree with cooter. Its pretty easy swap with later crossmember. I did this on my 67. All bolt holes lined up except 2 and those needed openened up a bit w/ die grinder, I re-routed brake lines to front of croosmember like later model and used prop valve and master cylender from same truck. I also made a spacer for the steering box to get around not having dimple on frame. Make sure and check fittings from pump to box. Don,t ask me how i know this. Evidentaly chevy changed to threads somewhere along the way. If you get pump and box from same truck this shouldnt be a problem. Hope this helps. Greg
  1. 1967 Chevy small window SNB 350 auto 3/5 drop ps/pb {project}
  2. 1969 Chevy LWB 350 auto factory air mostly original rustfree (dependable cruiser)
  3. 2000 GMC Sierra X-Cab Z71 (Wife's ride/Grocery getter)
  4. 1969 Pontiac GTO (Restoration started. Purchased by Aunt new)
Okie Bucket is offline   Reply With Quote
Old 02-06-2007, 05:50 PM   #8
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
unre,If you swap to a later frame the only option is a 71-72.The front crossmember works from later on the early frames but the frame itself is different.You can make anything work as long as you have plenty of $$$ to throw at it but it's really easier to use your frame and uppdate.If you have a running,driving truck you may want to buy a frame to build so that your foundation is complete when you get ready to swap your cab and bed.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 02-06-2007, 08:10 PM   #9
BigTex
My ultimate plan is to use the complete rolling chassis from either a 1999+ Chevy 4x4 or a 2000+ 4x4 Tahoe. Tahoe is within 1" of the 67-72 wheelbase. 99+ SWB is 2.5" longer. That would give me 4 wheel antilock brakes, a stronger frame, GenIII mounts, power steering, increased reliability, and no rust. I'll convert it to AWD like my Silverado SS, so traction won't be an issue.
Richard
1970 Chevy (growing pile of parts)
2003 Silverado SS
BigTex is offline   Reply With Quote
Old 02-06-2007, 08:35 PM   #10
cooters
ive got a 94 Z 71 chassis sitting here waiting for a 71 body. Looks like a good fit but need some time
Old 02-06-2007, 09:12 PM   #11
BigTex
cooters - you have any pictures of that chassis? I'm familiar with the current model 4x4 trucks front suspension, but wanted to physically see how that model line was setup. If you have some, you can send them to richard@z71.net
Richard
2003 Silverado SS
Old 02-07-2007, 11:22 AM   #12
unreconstructed1
nec absolutum
thanks for the input ya'll. I tried to get some pics, but they didn't turn out right. I'll be posting some as soon as I can probably today. thanks again.
Old 02-07-2007, 12:04 PM   #13
unreconstructed1
nec absolutum
ok here ya'll go
and one more
god, i love that truck
Old 02-08-2007, 06:24 AM   #14
There ya go.It`s funny,this started out with everyone but me saying you don`t need to do all that work to swap frames,just put the parts on your frame,to talking about all these plans to put other frames under their trucks to get modern benefits...
I still say,if your restoring the truck and tearing it down,it would be way easier to get a donor truck or just frame to do your upgrades.There`s nothing "piece-o-cake about swapping front end assemblies,crossmembers,and all out from 35+ year old trucks(remove twice).
Old 02-08-2007, 12:14 PM   #15
gyjackson
I just removed all the crossmembers and running gear from a 72 frame to do a 4x4 conversion. I now know more than I need to know about conversions.....That leaves me with a complete front crossmember (including P.S. and a Disc P.B. set up)
Shoot me a PM and we'll talk if you like. Maybe I can help you out with some suggestions.
'72 Custom/10 SWB project... converting to 4WD
'67 Camaro rs convertible...waiting in line
'99 Ext. Cab Z-71 190000 miles on orig. trans fluid
'02 Black Z-71 burb..(wife's)
'92 Accord (daughter's)....Who want's my insurance bill?
gyjackson is offline   Reply With Quote
