Old 02-06-2007, 02:30 PM   #1
kevinr1970
Air intake kits
I bought a Fram Boost air intake kit and installed it on my truck Sunday morning.
I notice that when it is idling in nuetral if I tap the gas ever so slightly it takes a split second for it to respond. Before it started revving imediately.
It also seems to stumble ever so slightly at the beginning of the rpm range.
I checked all my connections to make sure there was no leaks and all the hose clamps are tight.
Do I need to get it reprogrammed to compensate for the air intake kit? Should I need to have it reprogrammed?
Any ideas?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 02-06-2007, 07:39 PM   #2
dailydragger03
dailydragger03's Avatar
Re: Air intake kits
I know this sounds crazy but, I put an AEM bruteforce on my truck and it kind of did the same thing. After driving it for a couple of days it stopped. It was like the ECM had to learn what the intake was doing. I have had mine for almost 2 years now and Iv'e never experienced the problem again.
dailydragger03 is offline   Reply With Quote
Old 02-06-2007, 08:37 PM   #3
kevinr1970
Re: Air intake kits
Another guy I talked to said to wait a week.
Good to know its not just me!
2000 Tahoe Limited
Old 03-02-2007, 12:32 AM   #4
dinnut
dinnut's Avatar
Re: Air intake kits
your computer needs to adjust. but if your new filter is oiled like my new k&n was, youll need to clean your mass air flow sensor. get a can of mass airflow cleaner from your local parts house. take it off the truck and spray it a couple times let it dry off and reinstall should help it out some. if it doesnt let up in a few days clean the maf
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
