Old 02-08-2007, 08:59 PM   #1
jkade
jkade's Avatar
BBC Serpentine Brackets Installed with Pics?????????????
I am down to getting a upper radiator hose and wanted to see if anyone else has done this swap and how they ran the radiator hose.
jkade is offline   Reply With Quote
Old 02-08-2007, 09:42 PM   #2
dwaite72lnghrn
Re: BBC Serpentine Brackets Installed with Pics?????????????
Here is mine I am going to replace the stock intake snout with one that points to the side this spring. It has a stock NAPA top rad hose. it rubs just a touch on the alternator now. As you can see you run out of room to the rad and I can't find a electric setup that is less than 2". I am banging out a shroud for the fan because the 14" and 10" fans in front of the airconditioner can't keep up in the summer.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 02-08-2007, 10:37 PM   #3
jkade
jkade's Avatar
Thanks for the pics, that is the exact brackets I have. I wanted to run mine in front of the alternator but I may have to do like you did. I may end up fabbing a aluminum pipe in the long run. Is there any chance you have the number on the serp belt? What year is you setup and what did it come off of?
Old 02-08-2007, 10:41 PM   #4
jkade
jkade's Avatar
These are the thinest fans I can find. Summit has them new for $209
http://cgi.ebay.com/ebaymotors/ws/eB...1198&rd=1&rd=1
Old 02-09-2007, 05:03 AM   #5
dwaite72lnghrn
This was a GM kit. When I put the crate motor in the truck I wanted a new waterpump and alternator and power steering pump as most of them were factory except the alt which was 16 years old. When I priced them out it was cheaper to get the kit that the units seperately. The kit came with the brackets for tall deck and everything belts/bolts/brackets/WP/ALT/PWRSTRpump/airconditioner compressor/ both belts. I will check my book I keep in the truck and get the part number for the belt.
2009 HHR aqua blue
Dave & Jeanne
Old 02-09-2007, 11:06 AM   #6
kwmech
That is the long water pump---right?
Old 02-09-2007, 11:26 AM   #7
GMCBubba
GMCBubba's Avatar
fan 2.2" http://cgi.ebay.com/ebaymotors/10-IN...QQcmdZViewItem
there seems to be several that are less than 2" on the outside, but the centers all run a little thicker. good luck finding something
1969 GMC 3/4 ton, 307, 4-speed NP435GL, DANA 60, 4.10, HD rear leafs, manual everything, leaking oil and water. Now rocking 383, NV4500, power steering, power brakes. Finally undergoing restoration.
GMCBubba is offline   Reply With Quote
Old 02-09-2007, 10:40 PM   #8
dwaite72lnghrn
I keep a log book in the truck and when I put something not factory on the truck I write in the back the part numbers. That way if I break down on the road it is easier to get replacement than saying it's a '72 with a serp setup off an '9x truck.
Serpentine belt #88986813.
Long water pump #12560471.
2009 HHR aqua blue
Dave & Jeanne
