02-12-2007, 09:58 PM | #1 |
Manual Choke
Just wondering if you guys changed out the manual choke to automatic choke, on your trucks. Or what is the best thing to do.? Any opinions will help
02-12-2007, 10:04 PM | #2 |
Re: Manual Choke
well you can install this kind of hooky set up with a stock carb
http://www.carburetion.com/quadrajet.asp or you can get a 75 truck carb with a hot tube choke and convert it Last edited by rage'nrat638; 07-12-2007 at 06:56 AM. |
02-12-2007, 10:06 PM | #3 |
Re: Manual Choke
this is the stock spring box set-up
02-12-2007, 10:07 PM | #4 |
Who's got steelies?
Re: Manual Choke
Eventually, when I get the q-jet installed, I am going to go manual choke. The 2-barrel I'm using now has the later style auto choke and it usually works good (2GC). I've had problems with the auto choke that have the coil mounted on the manifold (2GV type); the later kind mounted to the carb works much better. What kind of carb are you using?
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
02-12-2007, 10:09 PM | #5 |
Re: Manual Choke
it's the original single barrel carb that's in their. rochester.
02-12-2007, 10:22 PM | #6 |
Who's got steelies?
Re: Manual Choke
Might have to go to a salvage yard and find a later 1 barrel, say from a mid 70's straight 6 truck.
02-12-2007, 10:25 PM | #7 |
Re: Manual Choke
i'm in california so is manual choke really that necessary, or should i just change it out completely.
02-12-2007, 10:31 PM | #8 |
Who's got steelies?
Re: Manual Choke
If it is annoying to use the manual chike, then I'd say replace it with an auto choke. But if it stays warm enough (shouldn't have to use the choke if it is 60-65 degrees or warmer) and you don't have to use it, then leave it in. Have you been having trouble with the carb and thinking about upgrading?
02-12-2007, 10:35 PM | #9 |
Re: Manual Choke
actually i'm in the process of restoring it, and just wanted to get informaiton ahead of time so I can plan ahead. so might be easier just to rebuild it and leave it as is.
02-12-2007, 10:49 PM | #10 | |
Who's got steelies?
Re: Manual Choke
If you wanted to convert to an auto choke, the easiest thing to do would be to get a mid 70's 1 barrel with the auto choke mechanism mounted to the carb itself. Either way, unless you buy a new carb, you'll probably have to (or want to) do a carb rebuild.
02-12-2007, 10:47 PM | #11 |
Junior Member
Re: Manual Choke
My son tells me that a well tuned engine does not require a choke, so he does not have one on his 70 C-10 with a 350 and a Holley carb.
I on the other hand have a 71 C-10 with a stock 350 with a quadra-jet and have converted it to a manual choke. Danny - Southeast Missouri 71 C-10 Pretty much stock except for it has a 70 Camaro 350 engine |
02-12-2007, 11:44 PM | #12 |
In Memoriam...
Re: Manual Choke
Personally, I like the direct action and mechanical goodness of a manual choke. Makes me feel as one with my machine.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
02-13-2007, 02:25 AM | #13 |
Re: Manual Choke
dont see how if an engine is tuned well it would not need a choke.
An old racer put a manual choke on mine,. it is just a cheap one 25.00cable a bit more expensive would have been better but it works well and I like the fact that I can kick it down to a number of RPMS, whatever Idle I want and leave it there till I want it off. Should do the same for my Wallywagon, it races till it is good and ready and can't be kicked down till it is ready. That can be adjusted by putting solder onto one part till you get the right amount of weight then it will kick down sooner. May get the mechanic to do that. Warren |
