02-13-2007, 01:21 PM | #1 |
Temperature problem! Need help...
My temp. gauge keeps fluxuating to hot and back down to normal, but the engine does not seem to actually be running hot (no steam, etc.)!? As long as the truck is moving the temp will hold steady, but if I stop for a period of time with the engine idling, the temp. will start going up and down again.
Is this a bad thermo? Is there a sending unit that may be bad? Have any of you guys had similar trouble. The engine is a GM 350. Thanks, Jeff |
02-13-2007, 01:37 PM | #2 |
Re: Temperature problem! Need help...
sounds like the thermostat is closing early and opening late. That would be my guess, or a flow restriction.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
02-13-2007, 02:05 PM | #3 |
Could be a partially plugged radiator (flow restriction) or even low on coolant. Is the radiator actually full????
1971 Shortbed 350/350 w/ Posi-traction 3:73's 1996 Chevy Silverado TJ in Springfield, Virginia Likes old Chevy trucks Drinks Miller MGD |
02-13-2007, 03:18 PM | #4 |
A radiator hose isn't bad is it? That was my problem once. Thought it was the thermostat, changed it but neglected the hoses. Ran well for a day, then blew the lower rad hose off. Just a thought.
1969 C/10 swb, 350, powerglide (daily driver) 2005 CRV (wife's ride) |
02-13-2007, 03:21 PM | #5 |
its all about the +6 inches
that sounds like classic sticking t-stat, or low coolant level.
02-13-2007, 04:12 PM | #6 |
The Fastor Pastor '68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed: '70 swb; TH-400 - bagged & shaved. Looking for new engine or parts. Wife - Original {A Real Classic!} |
02-13-2007, 08:12 PM | #7 |
is your sender on top of the thermostat housing? This would happen in that case. Otherwise it seems to be a thermostat problem
02-14-2007, 04:00 AM | #8 |
whens the last time you changed the t-stat? because just like everyone has said thats most likely what it is
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
02-14-2007, 03:56 PM | #9 |
Thanks ya'll! I'll check the levels soon. I know for
sure its not a bad hose. I just replaced both about 3 months ago. If the coolant level is appropriate, I'll just get a new thermo and try that out.
Thanks again for your responses. |
02-15-2007, 03:43 AM | #10 |
To The Levy
what about the wire from the sender to the gauge, is it intermittantly shorting out ?
