Old 02-16-2007, 05:29 AM   #1
BUXMAN66
go bucks!
some more pics....
try a coulpa more...
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 02-16-2007, 05:56 AM   #2
BUXMAN66
go bucks!
Re: some more pics....
got a lot of parts to put on the ole girl... redid the whole front suspension....sand-blasted the upper and lower control arms,new coil springs,pressed in new c.a.bushings,ball joints,tie rods,center link,rotors,calipers.....etc. allparts were coated in por-15 glossy gray.waitin' for the weather to break some it be dang cold out there in the garage.i got a new furnace hung up but the walls are'nt insulated yet. bought a new gennie shifter for a automatic....23"swan check 'em out here:www.gennieshifter.com surprised more guys don't have these in their trucks on the board.most of us are into rods and customs rather than the restored.....trying to score a dieterich sunvisor also.
Old 02-16-2007, 07:56 AM   #3
Detroit3100
dude insulate. I did mine and here in michigan I can get my garage up to 50ish when it is below zero outside. Looks good.
Detroit3100 is offline   Reply With Quote
Old 02-16-2007, 02:31 PM   #4
BUXMAN66
go bucks!
oh, i'm plannin' on it alright.... just have'nt gotten around to it yet,... been putting all the excess money in to the truck ....or my latest toy,a new 80 gallon air compressor and sandblast cabinet!luckily i work in a machine shop and i can get the filter,regulator and oiler for the steel lines for free.....btw, i got a pole barn style of garage which has the posts on 8ft centers.how did you insulate your garage? i been thinking of going w/ 4'x8' foam board ,2" thick.....anybody got any suggestions?
Old 02-16-2007, 03:13 PM   #5
Marty Gable
Still working on the COE
Marty Gable's Avatar
My dad did his (2400 sq ft) actually framed it and used reg 16" w insulation paper backed then rocked and textured it.... little bit more time and money but well worth it... otherwise check into a spray foam style
Marty Gable is offline   Reply With Quote
Old 02-18-2007, 05:03 AM   #6
SURFER1316
i'm helping my girlfriend's father finish up a 40x40 shop right now. And he's using this aluminum stuff, 14.5 r-value and doesn't need to be covered or anything, works as it's own vapor barrier, and it's fire rated, then we're throwing up plywood to cover up the bottom 8' of each wall, and leaving the insulation exposed the rest of the way to the roof (about another 7 feet). And like it so far, but the heater hasn't been hooked up, and haven't seen it through the first cold spell, will have to get back to you on that one.
here's the stuff... http://www.insulation4less.com/
SURFER1316 is offline   Reply With Quote
Old 02-19-2007, 02:35 AM   #7
BUXMAN66
go bucks!
yeah i'm interested in finding out how it holds in the heat w/ the furnace/or the heat source hooked up....thanks! i saved that place you mentioned in my favorites!
Old 02-19-2007, 11:18 AM   #8
Jebb1978
Jebb1978's Avatar
Truck looks really sharp!
1959 GMC project
Jebb1978 is offline   Reply With Quote
Old 02-19-2007, 08:19 PM   #9
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
lookin good keep the pics coming
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 02-20-2007, 04:31 AM   #10
BUXMAN66
go bucks!
thanks guys for the compliments! it sure has been a lot of work as many of you know.....
Old 02-20-2007, 03:02 PM   #11
SURFER1316
should hold up good, it's stapled to the boards that support the metal walls, I actually put up a few sections of it this weekend, and it's easy to install easy to cut, seems pretty quality stuff, but I'll make sure i update you as soon as the heater/ac is hooked up
Old 02-21-2007, 03:33 AM   #12
BUXMAN66
go bucks!
thought i'd try to put a couple more on here...just figgered out how to resize pics!!
Old 03-01-2007, 05:55 AM   #13
BUXMAN66
go bucks!
here are some of my progress pics. all the suspension is done....next is mounting the new gennie shifter!
Old 03-01-2007, 11:14 AM   #14
CAL 58 GMC
CAL 58 GMC's Avatar
Nice work!! Your going to have a awesome truck when your finished!
CAL 58 GMC is offline   Reply With Quote
Old 03-02-2007, 04:59 AM   #15
BUXMAN66
go bucks!
thanks cal.....if mine looks as good as yours in your avatar i'll be happy!!
Old 03-02-2007, 06:13 PM   #16
84 400
Sb 400 club
84 400's Avatar
Wow nice work. I also am a fan of gennie shifter products. and like you am suprised i don't see more of them. but i guess there is alot of compition such as lokar and the like.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
