02-17-2007, 11:30 AM | #1 |
Where's your tach?
I have an AutoGuage 3 3/8" tach that I would like to put in my 86, but I can't figure out where to put it. I don't want to put it on top of the dash. The only place I can see it might work would be on the column in front of the shifter. Any ideas?
02-17-2007, 11:36 AM | #2 |
Re: Where's your tach?
That is where I have mine. Don't really like it there, but like you said there is not another place. Don't want to put holes on the dash pad.
02-17-2007, 12:19 PM | #3 |
You get what you pay for
Mine is right here.
Mike 1985 Chevy C-10 |
02-17-2007, 12:23 PM | #4 |
02-17-2007, 01:35 PM | #5 |
The One And Only !!!
Hey swervin nice ! Is that a factory tach cluster and what's the scoop on the shift indicator lights ?
I'm not familiar with the later trucks since mine is a 74.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
02-17-2007, 02:06 PM | #6 |
needin' money
on the dash, at the bend
SWB Stands for Short Wide Bed |
02-17-2007, 03:16 PM | #7 |
Depends on what you are using the tach for . Mine are factory in the dash on my 77 and my 78 . If you are just using it for reference mount it on the bottom of the dash looking up or near the roof on the driver a pillar . If you need to see it for shifting , mount it where you dont have to take your eyes off the road too bad . I seen one that the owner built a bracket that uses the sun visor mounting point . It wa cool and no extra holes were required . Frank
Born and proudly residing in a Red State ! |
02-17-2007, 03:23 PM | #8 |
Mine is mounted on the dash and my shift light is mounted around the steering column on the 87 short wide.
1973 Chevrolet C20 (Under Construction) |
02-17-2007, 05:30 PM | #9 |
Mine is on the dash, dash pad wasnt perfect anyway
75 GMC C-15 short/step factory 454, lowered |
02-17-2007, 06:51 PM | #10 |
Sb 400 club
I have not mounted mine yet but was thinking i will go were the red scribble is. Mine is a Sun pro II 3 inch. I tried mounting it on the colum but with having a tilt and auto it was just too much of a pain. To me down below is uslesss. True i don't really need it but thik it would be nice to have. IS there another way of mounting it with out drilling my dash? Also i have heard of the piller idea but still don't get it . anyways thanks
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
02-17-2007, 09:02 PM | #11 |
No it's not a factory tach cluster.
http://www.73-87.com/7387garage/inte...s_recessed.htm The article is from long ago. I have updated things since I wrote it. The shift indicator lights were moved from top center. They are so I can have a high beam, park brake and choke indicator lights. I added the shift light and the two gauges where the radio was, plus the billet bezel. Mike |
02-17-2007, 10:11 PM | #12 |
Sb 400 club
mike it looks really *****en. nice job
02-17-2007, 10:34 PM | #13 |
Nice Erv but is the choke light really needed.
02-17-2007, 11:39 PM | #14 |
Parts and more parts
I mounted mine and the son's on the left front pillar, just above the dash. (No Holes in the dash and I used the factory screw hole), so it could be removed and look clean. The tach is mounted to a piece of aluminum strapping that is tapered to follow the windshield rubber to hold it in place. It works well and the tach is right below eye level and easy to see.
02-18-2007, 02:16 AM | #15 |
Sb 400 club
Peiceparts, you have mentioned this before and i think this is the way i am going to do mine. could you provide a picture of the setup or maybe a drawing? Also what tach are you running? I would really like to do the autometers but don't have the money right now. And i have a tach waiting to be hooked up.
thanks
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out Last edited by 84 400; 02-18-2007 at 02:19 AM. |
02-18-2007, 03:55 AM | #16 |
02-18-2007, 09:11 AM | #17 |
Diesel Addict
Mine is in the factory Cluster, sitting on my work bench
1979 C-10 Silverado w/ Olds 5.7L Diesel |
02-18-2007, 11:11 AM | #18 |
84 400 if you look at the attached thread that 84sloppwaggin attached: Is there any more that you would need from those pictures?
02-19-2007, 12:32 PM | #19 | |
Sb 400 club
thanks
02-19-2007, 09:23 AM | #20 |
I put mine on shifter column but i put it so that when shifter is in drive the tach is positioned on top Ill have to try to get a pic but dont have one right now
02-19-2007, 05:20 PM | #21 |
the green machine
just for reference
1975 Silverado - 450 horse crate 383 stroker, 20" Centerlines, Flowmaster exhaust, Hooker headers, full MSD ignition & more... 2003 Suzuki TL1000R 1985 Kawasaki JS550 hull - project ski - WILL have - 650, footholds, custom paint, 4* bars, bilge setup, and more... My pictures |
