Old 02-18-2007, 11:44 PM   #1
Dano69c10
Dano69c10's Avatar
Removing front coils w/o spring compressors.
If I jack up the frame and remove the front wheels and get full downward travel from the a-arms can I remove the front (stock) springs w/o a spring compressor?
Just wondering if there will be any spring tension when I go to remove the lower a-arm u-bolts.
Thanx in advance.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 02-19-2007, 12:05 AM   #2
5150
C10 Club Tennessee
5150's Avatar
Re: Removing front coils w/o spring compressors.
there will be tension, just lower the lower a-arms with a jack SLOWLY!!!!!!!
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 02-19-2007, 12:12 AM   #3
dave2953
Dave's not here, man
dave2953's Avatar
I've heard stories about springs wreaking havoc if they come flying out. Like Yellow69 said, take your time.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 02-19-2007, 12:38 AM   #4
Shane
Shane's Avatar
place truck on jack stands
place floor jack under lower control arm
loosen TOP spindle/ball joint nut - but do NOT remove yet
hit top portion of spindle to un-seat ball joint
re-check floor jack and make sure it has tension on lower control arm
remove spindle nut
sl-o-o-o-o-owly lower floor jack
remove spring
repeat on other side
reassemble in reverse order
open beer
stand back
admire work
Shane is offline   Reply With Quote
Old 02-19-2007, 08:54 AM   #5
49studebaker
49studebaker's Avatar
I like shane's way of thinking! I actually rented a spring compressor, of course the highly trained and experienced folks from Checker Auto gave me a strut spring compressor(no it didn't work and yes, the Checker employees in this town don't even own vehicles). So I did it like Shane says. The only problem was that my truck was down to the bare chassis and so I didn't have the weight of the truck to push against once it was time to put them back in. I ended up using tie downs to cinch them up close enough to get the ball joint nuts on.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 02-19-2007, 11:32 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
If your only replacing the spring and not the spindle there is another way. Same concept that Shane describes, but unbolt the u-bolts that hold the A-arm to the frame and lower the back of the A-arm down slowly. Insert spring and repeat in reverse.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-19-2007, 11:49 AM   #7
Dano69c10
Dano69c10's Avatar
Thanx guys, luckily it is a bare rolling frame that I'm working with. I went to Kragen and they didn't have the right compressor. (Is Kragen and Checker related?) I did run a chain through the spring just in case it decided to fly, but it was not needed.
Dano
'69 Fleet
