Old 02-26-2007, 07:09 PM   #1
jtm
jtm's Avatar
vent window removal-help????
how do you get the vent windows out..trying to clean them up and replace the weather stripping. have taken the inner door panels off and see the extension for the window...before i try and get that bolt off, anyone done that before?
wherever you go...there you are...
jtm is offline   Reply With Quote
Old 02-26-2007, 09:28 PM   #2
hewlett2002000
hewlett2002000's Avatar
Re: vent window removal-help????
you slide it open and pull it out, at least thats how i did it on my truck.
Respect:
1. A feeling of appreciative, often deferential regard; esteem.
2. The state of being regarded with honor or esteem.
3. Willingness to show consideration or appreciation.
When you fail to show consideration to others values you are showing disrespect.
hewlett2002000 is offline   Reply With Quote
Old 02-27-2007, 01:09 PM   #3
jtm
jtm's Avatar
hmm...trying to get the entire thing out, frame and all...know there is one rivet I need to pull where it pivots...so it will just pull out other than that?
Old 06-10-2008, 06:31 PM   #4
c10Mang
c10Mang's Avatar
Hey I am trying to replace the frame also, what did you end up doing?
thanks,
c10Mang is offline   Reply With Quote
Old 06-10-2008, 06:39 PM   #5
scotts62
One day...
scotts62's Avatar
Have you already got the whole track and window out? or are you trying to get that out too?
Scott
93 crew cab build
Project 62
Old 06-10-2008, 06:51 PM   #6
jchav62
1962 C-10
jchav62's Avatar
The are 4 or 5 philips head screws around the door jamb part of the door that have to be removed. Then you have to remove the door panel and remove a clutch head screw that is attached to the lower part of the channel. Roll the window down and wiggle it out from there. There's a little twisting and turning involved... Good luck...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-10-2008, 07:22 PM   #7
LILRED66
LILRED66's Avatar
There are three phillips head screws on the front angled edge of the door...one down low, one in the middle and one up at the top of the wing window. There are two phillips head screws behind the door panel below the window regulator. With the window rolled down, tip the wing window assembly, frame and glass, back into the window opening. As it tips back, pull it up and rotate it 90 degrees in toward the cab. There is a an oversized area where the wing window assembly track is allowed to slide out of the opening.
To install, repeat these steps in reverse. I hope this information is helpful and good luck with your project.
LILRED66 is offline   Reply With Quote
Old 06-11-2008, 02:50 PM   #8
c10Mang
c10Mang's Avatar
^^ thanks guys!!
How about getting the window out the frame? And this lil bolt?
Old 06-11-2008, 03:58 PM   #9
joe231
joe231's Avatar
the window will pull out of the frame, might have to run a razor blade around it.
that is a rivet, you will have to drill it and replace it with the proper one.
why do you need to remove it?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-11-2008, 04:12 PM   #10
Woogeroo
What LilRed66 wrote to get the whole assembly out... to get the wing window out of the assembly/unit/frame...
That thing yer arrow is pointing at must be drilled out. You can buy a new one and repress it in.
American Classic calls it the: Rivet, vent window upper pivot
After you get that out, you look at the bolt at the bottom of the vent window, which you use to adjust the tension on the spring down there, to keep the window in position when yer riding along...
Here are some pictures of the bolt, with the vent window still in the truck door.
You take that bolt loose, the spring comes off... you turn the vent window sideways, like when it's open and slide/wiggle the rod out of the bottom of the frame.
I've been told by several folks that replacing that vent window seal is quite a job, until you get the hang of it.
-W
Woogeroo is offline   Reply With Quote
Old 06-11-2008, 04:16 PM   #11
joe231
joe231's Avatar
well duh!
guess you have to pull it out to replace the seals huh?
I believe the vent seal kit comes with the new rivet doesn't it?
edit:
guess not here is the linky for the rivets and tool
CHEVY ONLY
Old 06-11-2008, 07:04 PM   #12
scotts62
One day...
scotts62's Avatar
Ya those can be a pain if you have not messed with them ever, but its not too terribly bad. it did take me a while to do mine.
Hey if that doesnt work just one piece window it
Scott
93 crew cab build
Project 62
Old 06-11-2008, 07:18 PM   #13
LILRED66
LILRED66's Avatar
You can also dip the window assembly in hot water to loosen up the setting tape, in addition to running a razor blade around it per joe231's suggestion.
Old 06-11-2008, 10:18 PM   #14
c10Mang
c10Mang's Avatar
Thanks for all your help, here is a pic of the frame:
