Old 02-26-2007, 10:54 PM   #1
Texasdeere
Texasdeere's Avatar
Serial # Location TH400?
I was trying to figure out if the TH400 transmission in my 72 C10 was original. I had the hump off the other day and found the tag on the passenger side of the case with some #s on it. Is this the serial # tag? or is it stamped in the case somewhere?
Texasdeere is offline   Reply With Quote
Old 02-27-2007, 09:42 PM   #2
Rod
Re: Serial # Location TH400?
The tag decodes the year ...usually the second number is the year.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-27-2007, 10:14 PM   #3
Texasdeere
Texasdeere's Avatar
I was told or heard that part of the serial # of the engine and trans should match the vin of the truck. I haven't found the serial # of the engine yet but the casting # I found is correct for a 72 402 anyway (3999290).
How do you figure out if it is a "Matching Numbers" truck?
Old 02-27-2007, 10:24 PM   #4
Rod
http://www.nastyz28.com/chevy-transm...tification.php
Old 02-27-2007, 10:27 PM   #5
Rod
http://www.nastyz28.com/sbchevy/sblock.html
http://www.nastyz28.com/bbcmenu.html...FTjTJAod8jJ2gw
http://www.nastyz28.com/chevy-engine...ngs.php#suffix
Old 02-27-2007, 11:06 PM   #6
Texasdeere
Texasdeere's Avatar
Thanks Mr. Rod!
Old 03-10-2007, 05:38 PM   #7
Texasdeere
Texasdeere's Avatar
I found T0406TLM stamped on the front pass side of the block on a pad just below the cylinder head. The guide said it should be above the timing chain cover at the center of the engine.
So far : Tonawanda, April 06
Guess I will look for the clock next!
