Old 02-28-2007, 05:37 PM   #1
setandreel
setandreel's Avatar
65 C-10 paint?
Hey all
I have a 65 C 10 standard cab swb stepside my question is on the factory paint, the trim label on the kick panel drivers side says the paint is fawn, is that inside and out? the p.o. painted the outside turqoise and the inside is like a goldish beige, the inside look like it has never been painted, so did chevy paint the outsides one colour and the insides another? I can't find a label any where giving the interior colour. I am wanting to back factory colours.
Thanks in advance
Mike
setandreel is offline   Reply With Quote
Old 02-28-2007, 06:10 PM   #2
chevroletrestoguy
Re: 65 C-10 paint?
my 65 c-10 was light blue and the interior is gold like yours. I saw no mention of interior color anywhere in my references.
chevroletrestoguy is offline   Reply With Quote
Old 02-28-2007, 09:36 PM   #3
ol Curt
Junior Member
ol Curt's Avatar
Re: 65 C-10 paint?
That is correct. The insides were Fawn Metallic.
ol Curt is offline   Reply With Quote
Old 02-28-2007, 11:51 PM   #4
Fred T
Cantankerous Geezer
Fred T's Avatar
Re: 65 C-10 paint?
To determine the exterior color try sanding through the turquoise. Usually there will be places that were just sanded down, where the original paint was still good. Door jambs are usually good to try.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 03-02-2007, 10:19 PM   #5
factorystock
factorystock's Avatar
Re: 65 C-10 paint?
The trim plate says it was originally painted fawn on the exterior. This is not the same as the interior metalic fawn gold color all trucks were painted.The fawn color was a beige-tan and was used one year only between 64-66.Also, yellow and maroon were 1965 one year only colors, and not used in 64 or 66.
factorystock is offline   Reply With Quote
Old 03-03-2007, 02:32 PM   #6
setandreel
setandreel's Avatar
Re: 65 C-10 paint?
Hope mine turns out that nice factorystock, where can I find the painted hub caps ? Everyone carrys only the crome ones
Mike
Old 03-11-2009, 07:12 PM   #7
rookierodbuilder
rookierodbuilder's Avatar
Re: 65 C-10 paint?
Mike
im not sure if this would work, but having taken a few chemistry classes, I believe that you may be able to reverse the plating of the hubcaps. much like using electrolysis to remove rust, you can use it to remove plating. I think you could use a dc circuit to do this. Im not sure about the polarity to do this though ( i think a positive on the hubcap and negative on a sacrificial piece of metal might do the trick). But being an amateur, I would say consult the experts first.
rookierodbuilder is offline   Reply With Quote
Old 03-12-2009, 09:06 AM   #8
jchav62
1962 C-10
jchav62's Avatar
Re: 65 C-10 paint?
Mike
Try Tony (LILRED66). He may have the caps you want.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-12-2009, 10:04 PM   #9
ol Curt
Junior Member
ol Curt's Avatar
Re: 65 C-10 paint?
Ima gonna tell ya. Finding four GOOD hubcaps will be hard to find, but if you watch often enough and want to pay enough there will be a set on ebay.
Ima also gonna tell ya the fawn trucks I have seen were very close to the interior fawn without the metal flake.
Old 03-12-2009, 08:32 AM   #10
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 65 C-10 paint?
those liook like 3/4 ton(clip type) which are probably real hard to find...
the 1/2 ton (snap on) I see on ebay quite a bit...
