03-02-2007, 10:36 AM | #1 |
3 speed manual
I have a 68 c10. The truck has a 250 that has parts from varrious vehicles, ie. intake and carb from a Buick. The engine runs fine after a little tinkering however, my transmission pops out of R and 1st after rolling about 10ft. 2nd and 3rd seem to be driveable, also this does not seem to be a linkage issue nor does the floor panel interfere with the shifter operation (originally a column but was converted to floor). My question is, does anyone know of a 3 speed GM manual transmission that has a 4 bolt side cover???? I know this does not match the description of the warners, saginaws, or muncis of that era. I currently do not have the casting numbers but can provide if needed. I suspect that this is an older tranny that was slapped in prior to my ownership. Any info would be greatly appreciated.
03-02-2007, 11:36 AM | #2 |
Re: 3 speed manual
Take a look at the FAQ Truck Tech area.
I know there is a good post on adjusting the 3 speed columns, with pictures.... http://67-72chevytrucks.com/vboard/s...d.php?t=215307 I thought there was one as well on installing a 3 speed floor shifter. Godd luck
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
03-02-2007, 02:46 PM | #3 |
Re: 3 speed manual
Thanks I'll take a look.
03-02-2007, 07:09 PM | #4 |
Re: 3 speed manual
OK I did find a site with a Muncie 3 speed with a four bolt cover. I also have the casting numbers as follows:
16 GM 3830210 T Also 3731911 is on the side cover GM t is on the tail |
