03-04-2007, 10:27 PM | #1 |
SB Chevy Valve Covers
My sons 70 C-10 has some Edelbrock valve covers that I guess are baffled on a 350 sbc v8. It takes 5-7 minutes to pour 1 quart of oil into the heads through the breather port without the oil overflowing. If my memory serves me correctly, my dad's 65 Chevy shortbed fleetside had I think a 1969 350 sbc with an oil filler cap on one of the valve covers...not a breather hole but just sort of a flat metal cap that would lock down when turned clockwise. Does Chevy or an aftermarket vendor make a valve cover with a capped oil filler hole in addition to the breather hole?
Thanks. |
03-04-2007, 10:38 PM | #2 |
Re: SB Chevy Valve Covers
look down in the grommet. When they come new, the bottoms arent cut out. Maybe the PO only cut a tiny hole in the grommet. That or someone may have put a baffle inside the cover.
03-04-2007, 10:41 PM | #3 |
WELCOME TO THE BOARD
03-04-2007, 10:44 PM | #4 |
Parts and more parts
Does the valve cover ONLY have a rubber grommet/baffle in the hole or after you pull the breather, can you see a metal piece inside? If it is metal, then you can take the valve cover loose and open that piece up a little and the oil runs down better. If it is the rubber grommet/baffle, then it can be opened more to allow oil addition. I have been using aftermarket valve covers and adding oil through the holes for the breather for years, there is always a way to make it better.
03-04-2007, 10:53 PM | #5 |
Spanked once
Went thru that the other day only it was 7 quarts
03-04-2007, 11:31 PM | #6 |
There is a metal plate just below the grommet...I presume this is the baffle. Both valves covers are the same. And it doesn't matter if I remove the rubber grommet or not..the oil can't be forced into the head any faster. I'm still hoping someone can confirm or refute my recollection of a stock GM valve cover that had two holes...with one of the holes having a twist on/off metal cap for the oil fill hole. If there was such a valve cover I would like to get my hands on a set. BTW...I will see if I can modify the current baffle in the existing cover to get better throughput. Thanks for all the help.
03-04-2007, 11:49 PM | #7 |
Insert Title Here
mine have the twist off metal cap... they are Goodwrench parts
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
03-05-2007, 12:01 AM | #8 |
You can go and buy a GM valve cover, and use them because they have more than one hole OR you can take the ones you have off and take a drill and open up some flow holes for the oil. I would look at how much room there is betweent the plates and the metal of the cover, there is undoubtedly a restriction. I personally would go for the revamp of the Edelbrock covers, but it is your choice.
On my covers, that I put my oil in throguh the same openings as the breather sits in, I have metal type baffles on them and I do not have to wait very long to get oil into the motor. It is a little slower than using an open hole, such as one with a fill cap, but it is quicker than what you stated in your query. Last edited by piecesparts; 03-05-2007 at 12:02 AM. |
03-05-2007, 01:11 AM | #9 |
Here you go... http://www.jegs.com/webapp/wcs/store...56593_-1_11355
If you want to keep the edelbrock valve covers, just remove the baffle and buy a push-in oil fill cap. This is the route I went when I lost one of my baffle studs. |
03-05-2007, 01:28 AM | #10 |
Thanks all...I think 1LoC10's pic of the Goodwrench valve cover is what I was thinking about...I really appreciate all the other info and the web link from AO50...Also...piecesparts, nice motor...you've got way deeper pockets than I do. Thanks again.
03-05-2007, 09:56 PM | #11 |
Mine has both a filler cap and grommet.
"Negative people always seem to have a problem for every solution" |
