Old 03-07-2007, 02:51 PM   #1
cojnit
Nothing clever
cojnit's Avatar
spring spacers, or swap them out
I am debating spring spacers of some sort or swapping the 3 inch drop springs for a 1 or 2 inch drop spring.
Any thoughts? also any ideas of how to raise up 1-2 inches in front? my wheel tire combo doesnt fit.
Got "the Midas Touch!"
cojnit is offline   Reply With Quote
Old 02-28-2009, 01:48 AM   #2
Ford Assassin
Ford Assassin's Avatar
Re: spring spacers, or swap them out
Bump, I need to know the same thing...
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 02-28-2009, 10:39 AM   #3
crazy longhorn
Fabricate till you "puke"
You would do best to just swap the springs, you will get a better ride crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
