Old 03-07-2007, 10:35 PM   #1
Captain Knievel
Captain Knievel's Avatar
Electrical help
My truck battery is draining almost nightly. So far I've replaced the battery and alternator (needed to upgrade to an Interstate battery and a chrome alternator anyway ), and removed all external add-ons that would draw power, including the radio, alarm, etc. Still ... draining. I'm a little stumped, and not too mechanically inclined. Could it be the voltage regulator? Could it be an evil fairy?
Thanks ahead of time for any help.
1970 C10
Captain Knievel is offline   Reply With Quote
Old 03-07-2007, 10:42 PM   #2
FLEET72
FLEET72's Avatar
Re: Electrical help
Here's what Bob has to say about that;
Here are a few things to try. One, remove the negative cable from the terminal and put a test light between the cable and the battery post. If the light glows, there is a drain. To find what circuit is causing the drain, remove one fuse at a time until the light goes away. Then, install them one at a time. When the light glows there is a drain, when the light is off, the bad circuit was removed. You may not get the light to turn off. In that case, it means that there is a drain in some other circuit that does not run through the fuse panel. First place I would look at is the starter. Starters have been known to short out at the solenoid and cause a constant drain to ground.
Good Luck!
Drive Safely!
Bob, The Auto Answer Man
Oscar
'72 Shortbed Fleetside
'95 Jimmy 4X4
'69 GMC Custom Camper
FLEET72 is offline   Reply With Quote
Old 03-07-2007, 10:45 PM   #3
sb69chevy
sb69chevy's Avatar
Re: Electrical help
Good info to have, Fleet.
1969 C/10 swb, 350, powerglide (daily driver)
2005 CRV (wife's ride)
sb69chevy is offline   Reply With Quote
Old 03-07-2007, 10:50 PM   #4
Captain Knievel
Re: Electrical help
I actually think the starter IS shot. I can't duplicate the noise it makes in this post. But you get the idea. I bought some shims, but maybe I'll go for the rest. I'm going to do the fuse thing first, though. Thanks!
1970 C10
Old 03-07-2007, 11:03 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Electrical help
If it was stuck points in the regulator you would have quite a spark when you disconnect the battery cable. It isn't a direct short to ground because you would have blown a fusible link or burnt the harness. A lot of these are caused by the horn wire under the steering wheel grounding and energizing the horn relay. If that was the case the horn should blow unless it has been disconnected. My .02
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-11-2007, 11:22 PM   #6
Captain Knievel
Re: Electrical help
So far it looks like the alternator I bought was a bad one. I exchanged it, reclocked that one, and installed that one. So far it starts right up. Now it sits for a few days. That will be the real test.
1970 C10
