03-12-2007, 07:52 PM | #1 |
frame paint
what is the best paint to use on the frame
my dad had some black epoxy paint left over from something so i used it this is what it looked like when finished it has been drying for a day and still seems wet any idea how long for it to dry? |
03-12-2007, 08:11 PM | #2 |
Re: frame paint
Did you follow the directions and add the hardener????
03-12-2007, 08:25 PM | #3 |
Re: frame paint
yes it says an equal amount of hardener as paint and i used 6 cups of each
03-12-2007, 09:17 PM | #4 |
Re: frame paint
Epoxy paint with hardener should be dry to the touch in about an hour at about 70 degree's.
03-12-2007, 09:42 PM | #5 |
Re: frame paint
Left over is the key. Hardener and paint has a shelf life. It should have been dry to the touch in an hour even if you put it on with a garden hose.
03-13-2007, 07:18 AM | #6 |
Re: frame paint
I agree with the guys above me "IF" it's an automotive paint, but if it's an industrial epoxy like rustoleum high solids mastic epoxy it will take longer even when new. I did two frames within the last 6 months with rustoleum and in a heated garage it took about 48 hrs @ 70 to dry. Also epoxy is temp. sensitive, if you don't keep it above 60 until it cures it may never harden correctly.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
03-13-2007, 05:42 PM | #7 |
Re: frame paint
Time To Get The Space Heater Going Asap
