how wide can i go?
how wide of a whell can i fit on my seirra with the stock wheel tubs? i want to run 15x8 rally wheels in the front and 15x10 or, if they will fit 15x12 rallies in the back. im pretty sure the 15x12s wont fit, but will the 15x10s fit without the tires sticking out past the fenders? i tried a search and drew a blank. thanks
yeller
Re: how wide can i go?
15x10's will fit no problem, here is my truck with them on the rear.
15x12's would be a close fit, and would require a lot of backspace to make work...even then, not sure the tires would clear the inner fenders if they did fit.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
thanks. the 15x10s look great on your truck, and if they fit ill go with them. what size tires are you runnin on them? any shots from the rear of your truck?
wow Jeff, Yeller is looking good! been a while since i saw one of your updates.
![]() Join Date: Apr 2005
I would love to run 10's in the rear with 275/60 and 8's in the front with the same tire size, but I don't know how that would look on a LWB. Oh and you can't rotate the tires with the staggered fit. That's my hangup. I'll more than likely just do 8's all around.
#6 | |
1984 Silverado SWB Second Owner Featured in Custom Classic Trucks May 2013 http://www.customclassictrucks.com/f...let_silverado/ |
paper or plastic?
I've got 20x12's in the rear of my stepside. 12" wide rims will fit.....Its all in the backspacing and tire width.
1967 Chevy SWB 250 http://67-72chevytrucks.com/vboard/s...d.php?t=442157 1977 Chevy SWB 454 No More 454 getting 5.3 http://67-72chevytrucks.com/vboard/s...d.php?t=310518 1977 Stepside Truck of the month winner http://67-72chevytrucks.com/vboard/s...d.php?t=135524 1965 Chevy C10 454 http://67-72chevytrucks.com/vboard/s...d.php?t=731372 1975 Dodge Power Wagon http://67-72chevytrucks.com/vboard/s...=1#post7871388 |
Parts and more parts
The whole trick is what backspacing you have on the wheels. You can order a set that has more backspacing and gain the room under the fenders.
I have a step side with 15X10 rallies and 325-50-15's on the rear. only have about 1/2" clearance. Buy the way, I have a 4/5 drop.
