Old 03-15-2007, 04:30 PM   #1
combustion
HELP WTf happened. (picture inside)
hello all. i need help figuring out what happened here. i started my truck today after my 454 swap and my steering box that hooks up to my ps pump busted open. i dont know what happened. im using the ps pump of the 1994 engine (my 454) that just bolted on
combustion is offline   Reply With Quote
Old 03-15-2007, 04:50 PM   #2
clay68c10
clay68c10's Avatar
Re: HELP WTf happened. (picture inside)
Time for a new box. Looks like the new pump found the weak spot of the system. The later 73+ boxes have a quicker ratio anyway.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 03-15-2007, 05:20 PM   #3
combustion
oh ok. sounds good.are they the same frame bol pattern?
thanx a lot
Old 03-15-2007, 05:32 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
not a quicker ratio, but a variable ratio
Old 03-16-2007, 12:18 AM   #5
BigSky71
LAIDOUT
BigSky71's Avatar
How does that work exactly? When does it vary? I have been thinking about upgrading mine to something better.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 03-15-2007, 07:18 PM   #6
woodridge
woodridge's Avatar
I've seen them get some water in them then freeze and burst like that.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 03-15-2007, 10:17 PM   #7
nvrforgotten52
nvrforgotten52's Avatar
yeah same frame bolt pattern
'69 C10 SWB 350 edelbrock int/carb .420 .442 cam 700r4
70 lwb c10 work truck 250 I6 with two inch lift springs and a two inch bodylift and 33/12.5s
nvrforgotten52 is offline   Reply With Quote
Old 03-16-2007, 09:17 AM   #8
hgs_notes
GEARHEAD
hgs_notes's Avatar
You have to check the hydraulic hose ends. There are two styles that are not compatible. So if you go to new (I think its 78 or 79) it won't work with the older pump and vise versa. BUT, you can replace both the pump and box from newer with no problem, just have the hoses also.
HG, Oh hey, this is my 500th post.
hgs_notes is offline   Reply With Quote
