Old 03-20-2007, 11:08 AM   #1
silvertonguedevil
silvertonguedevil's Avatar
Just bought a '62--couple questions...
First off--What's the difference between the basic heater and the deluxe heater? And secondly--Will a '71-'72 rearend bolt right into one of these? I see that the trailing arms are listed '60-'72. Is there anything else that I should know before I go scavenging for one? Any help is much appreciated!!
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 03-20-2007, 01:43 PM   #2
Captainfab
60-66 Nut
Re: Just bought a '62--couple questions...
The fresh air heater has the heater core and the fan in the engine compartment. This type works best in colder climates. The recirculating heater has everything under the dash. That design was intended for climates where it doesn't get very cold....they don't do a very good job of keeping the windows de-iced and fog free.
The 71-72 rearends are IIRC about 1 1/2" wider than the 60-66 rears. And I think the trailing arm perches on the 60-62 rears are spaced wider than the 63-72's. Other than that they will fit.....just some minor things.
Old 03-20-2007, 02:45 PM   #3
thekid54
I don't think the trailing arm perches are spaced differently on '60-'62 rearends. Don't have any proof since I got rid of my '62 frame, but I'm pretty sure the perch locations are all the same.
thekid54 is offline   Reply With Quote
Old 03-20-2007, 07:28 PM   #4
zenish
the perches are six inches farther out.you can get new perches from early classic.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 03-20-2007, 08:33 PM   #5
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
The trailing arm mounts on a '60-'62 IS 2 inches closer to the brake drum backing plates. On the '63-'66 the trailing arm mounts are 2 inches closer to the 3rd member(pumpkin). I had to install a '65 C10 rearend in my '62, in one day I had swapped axles, bled brakes, and down the road I went.
*note* I cut off the '65 trailing arm mounts in advance very carefully, I also prepped the axle tubes for welding. The day of the swap, I cut off the panhard bar mount off of the '62 rearend carefully(once removed from truck. Once I had the '65 rearend loosely mounted, I took a million measurements, then tacked everything together.
Once I was satisfied, I welded everything solid. When welding the brackets on the rear axle, weld in short runs, to stop distortion/warping from happening. I also reccommend replacing the big "U" bolts that holds the rear axle to the trailing arms. You might have to cut the old ones out.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 03-20-2007, 09:03 PM   #6
stepside66
stepside66's Avatar
I have a 62 and all I know is that my "66" wihch I found out was on a 62 LWB frame then made a SWB frame and not very good at that the rear end went out and I stumbled upon a 68?? I think but it had 6 lug axles wished it was 5 lug but I bolted it right in and never had a problem
stepside66 is offline   Reply With Quote
