![]() Join Date: Nov 2000
UPDATE!!--Quick Fuel Carb after defective BG Demon
I posted weekend before last about what junk BG Demon Carbs are after I got two in a row defective brand new Demon Carbs from Jegs. By the way, Jegs has great customer service. They never asked a question on any of my returns.
Well, I returned the 2nd defective Speed Demon 650 and decided on a 650 Mech, Quick Fuel Q-Series which has a Proform main body, and is basically a modified Holley Ultra HP, and is more of a performance carb. To make a long story short, I installed the QuickFuel out of the box and it's running just as good if not better than the first Demon I got which ran good but leaked gas. This carb I haven't even touched with the screwdriver, and it ran better than that first Demon and that Demon I spent some time on tuning it in. The QuickFuel seems to be a little meaner, and that's with the Vacuum from my tranny disconnected because I need a longer piece of vacuum hose so it was idling kinda funny. The QuickFuel carbs are engine tested and it shows cuz everything is pretty much on. Of course I'll probably fine tune the idle mixture, but the floats are good. Oh, and the red billet metering blocks and baseplate look real sharp! All I can say is I'm a happy camper with the Q-Series, and Jegs has 100% Customer Satisfaction and I can atest to that!! ![]() Last edited by 72step; 03-21-2007 at 12:30 AM. |
GEARHEAD
Re: UPDATE!!--Quick Fuel Carb after defective BG Demon
Isn't it so much nicer when something goes right for a change. Glad to hear it. RJ22
cool deal man, nice to hear the trucks running good, now you just need to put up some pictures cause you know how this board works...hahaha
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
67-72 Addict!
Did you get a mechanical or vac secondary carb?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
I also run a quick fuel carb on my BB454. I had it about two years and have no problems at all. Good Luck with yours.
A friend of mine had a bad experience with his Annular Booster Demon Carb. It had a machining burr left in one of the main jets (sloppy Quality Control). He discovered it when testing his 454 Corvette on the Chassis dyno. Picked up almost 100 HP when the day was done, most of which was attributable to the machining defect.
As far as the carb design is concerned, I hear it's a killer. Personally, I prefer Holleys. I have a 770 CFM Street Avenger atop my 70 Elky's 454 and a 750 DP atop my 69 C-10's 454. Love them both.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
Can we see some pics of the new carb installed?
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project |
You get to see the integrity of a company in how they handle problems. It's then that the good ones are separated from the bad ones.
Glad to hear everything turned out alright.
The Fastor Pastor '68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed: '70 swb; TH-400 - bagged & shaved. Looking for new engine or parts. Wife - Original {A Real Classic!} ![]() |
![]() Join Date: Sep 2005
Thanks for the comments. It's mechanical. I'll post pics tomorrow.
