Old 03-21-2007, 12:37 PM   #1
blazntn
Sfbd ??
Anyone have pics of how they did their stock floor body drop. I am installing Porterbuilt's Dropmember, and will be doing the rear when I get done. I want to lay the body on the ground. Does anyone have custom body mounts. I much will I have to lower the mounts?
Brad
blazntn is offline   Reply With Quote
Old 03-21-2007, 12:43 PM   #2
grnddwn
belly dragger
grnddwn's Avatar
Re: Sfbd ??
Is this a truck or a Blazer?
SAVE THE PLANET DRIVE AN OLD TRUCK
grnddwn is offline   Reply With Quote
Old 03-21-2007, 04:22 PM   #3
blazntn
Re: Sfbd ??
It is a 69 short wheel base. I will be running 22's all around.
Old 03-21-2007, 10:43 PM   #4
Jaredm82
Active Member
Jaredm82's Avatar
Re: Sfbd ??
I lowered my cab mounts 1.25" and it is more than enough to lay body...
Jaredm82 is offline   Reply With Quote
Old 03-28-2007, 07:04 PM   #5
blazntn
Re: Sfbd ??
Ok man, How did you lower them and remount them? What did you do to make sure everything lined up and was exact? Thanks
Old 03-28-2007, 07:22 PM   #6
Jaredm82
Active Member
Jaredm82's Avatar
Re: Sfbd ??
drilled out the rivets, cut the bottoms off them so they wouldnt hang lower than the frame, then measured a million times and welded them back on...
Old 03-28-2007, 07:34 PM   #7
7deuce
Sold! 2 days after finished
7deuce's Avatar
Re: Sfbd ??
Watch running thoes 22s and trying to go retarded low in the front. Youll be getting a million dollar set of custom offset wheels or making a custom hood like CAMAROTHUNDER. My 20s almost come to the top of the fenders.
7deuce is offline   Reply With Quote
Old 03-28-2007, 09:33 PM   #8
blazntn
Re: Sfbd ??
Well I will be running a 67 front end. I will have the dropmember. Wont the dropmember narrow the front enough to lay it all the way down and not hit the fenders?
Old 03-28-2007, 10:07 PM   #9
randomhero472
randomhero472's Avatar
Re: Sfbd ??
man, laying body w/22's sounds almost impossible, but im sure it can be done
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 03-28-2007, 10:15 PM   #10
PBFAB.COM
PBFAB.COM's Avatar
Re: Sfbd ??
We're in the process of doing this right now... I will post up some pics next week. The 22's are into the hood without the body-drop. It will get the "custom hood" treatment and possibly some custom control arms as well. It does have a Dropmember, but the offset on the wheel isn't quite enough. The customer had already purchased the wheels BEFORE he knew exactly what route he was (we were ) going to take.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-29-2007, 01:22 PM   #11
XXL
Señor Member
XXL's Avatar
Re: Sfbd ??
Originally Posted by porterbuilt View Post
It will get the "custom hood" treatment...
Will be looking for pics of this
XXL is offline   Reply With Quote
Old 03-28-2007, 10:50 PM   #12
1lowdiesel
1lowdiesel's Avatar
Re: Sfbd ??
if customs did it
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
Last edited by N2TRUX; 03-28-2007 at 11:52 PM. Reason: Keep the pics family friendly please.
1lowdiesel is offline   Reply With Quote
Old 03-29-2007, 12:18 AM   #13
1LoC10
Insert Title Here
1LoC10's Avatar
Re: Sfbd ??
laying body on 22's
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 03-29-2007, 01:57 PM   #14
FlatBrokeRacing
FlatBrokeRacing's Avatar
Re: Sfbd ??
WOW,
That truck is yellow...
FlatBrokeRacing is offline   Reply With Quote
Old 03-29-2007, 09:01 PM   #15
blazntn
Re: Sfbd ??
That yellow truck looks like it is running the stock hood? Does anyone have any pics of these trucks aired out with 22's? I just want to know what it will look like and how much lowered the body would need to go!!
Old 03-29-2007, 09:25 PM   #16
1LoC10
Insert Title Here
1LoC10's Avatar
Re: Sfbd ??
im pretty sure it is aired out in those pics, its on the ground
BOBBY
_69 SWB_
Old 03-29-2007, 11:38 PM   #17
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: Sfbd ??
Look how far back the centerline of the front wheel is from the center of the wheelwell. That just looks kind of goofy to me.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 03-30-2007, 02:21 AM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Sfbd ??
Are you doing something to remedy this on your truck? I think you may end up with the same affliction...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-30-2007, 02:47 AM   #19
BigSky71
LAIDOUT
BigSky71's Avatar
Re: Sfbd ??
I don't see any tail lights... what do they drop out from under the pan when its airred up? ha ha...
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 03-30-2007, 11:27 PM   #20
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
Re: Sfbd ??
Laying door with a 235/60/15
Laying door with 265/35/22's
My hood mods. not complete yet.
GOOD LUCK !
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 03-31-2007, 09:09 AM   #21
blazntn
Re: Sfbd ??
ya but I dont want to go all the way to the doors. I just want to lay rockers! I might even set it up to have the rockers about a 1/2" off the ground, just so I wont have to worry about trashing the paint.
Old 04-01-2007, 12:38 AM   #22
PBFAB.COM
PBFAB.COM's Avatar
Re: Sfbd ??
Here's some pics of the truck before we do the 'stock floor body drop'... (never really made much sense to me for somebody to call it that, by the time you're done tunneling for the trans and driveshaft it's not much of a stock floor anymore!).
The tires are 265 35 22's, they are currently into the hood (see pic) where the upper and lower skins are pinch welded and form an edge... before the body drop. We will be lowering the mounts and doing a custom hood treatment (like what IF custom's has done) to give the tires clearance at the hood.
I will be starting a build thread on the whole truck in the near future, and will reference the link in this thread as well.
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 04-01-2007, 02:38 AM   #23
XXL
Señor Member
XXL's Avatar
Re: Sfbd ??
The tires are 265 35 22's, they are currently into the hood...
That is an incredibly light hood!
Old 04-01-2007, 02:52 AM   #24
L0WRIDE
L0WRIDE's Avatar
Re: Sfbd ??
You have special powers when you're a super fabricator keep up the good work porterbuilt
49 CHEVROLET 1/2 TON, 52 CHEVROLET SEDAN
62 HARDTOP NOVA
65 CHEVROLET BB LWB FLEETSIDE
90 CHEVROLET EXTRA CAB
CHEVY ONLY - NZ Chapter
http://67-72chevytrucks.com/vboard/s...d.php?t=137984
L0WRIDE is offline   Reply With Quote
Old 04-01-2007, 03:52 AM   #25
SCOTI
SCOTI's Avatar
Re: Sfbd ??
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
