rear diff
I bought a 67 C20 Camper Special a while back, and someone told me recently that they all came stock with one ton rear diffs. Can anyone tell me if thats true?
Re: rear diff
I feel an answer coming forth from Longhornman
its all about the +6 inches
Re: rear diff
yes and no.
A camper special is nothng more than HD shocks, HD springs, HD tires, a sway bar, and badges... that is all that came in the option package. Now, the eaton/corp rear axle (identified byt a round salad bowl looking rear cover, and a drop out center section like a 9 inch ford) that came in a 3/4 ton, and that came in a one ton, are basicly one and the same... the brakes are all that was really beefed up. However, as a rear axle assembly, from drum to drum, the HO 52 (3/4 ton) and HO 72 (one ton) rears, are not the same. One other tidbit of info, if you have a coil spring rear, then it can not be used in a one ton, becouse one tons always had coils. |
Re: rear diff
#5 | |
![]() Join Date: Mar 2003
Re: rear diff
![]() DOH--too slow Last edited by kwmech; 03-26-2007 at 09:24 PM. |
Re: rear diff
LOL... yeah, I ment one tons always have leafs.
Thanks for pointing that out. |
Re: rear diff
I guess I was right eh?
Re: rear diff
Longhorn man, the cheese stands alone! you da man!
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
![]() Join Date: Dec 2006
Re: rear diff
Hey,welcome to the board 48 ish. Let's see some pics!
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
Re: rear diff
Thanks for the help guys. I'll post some pics as soon as I figure this site out. The 67 C20 has been sitting a long time and I havne't had a chance to do anything with it. Bought it to tow my 5th wheel after I beef it up. My baby is my 48- 350/700R4, Nova clip, Chevell rear suspension, air bags, custom dash, coast to coast 3 times, San Diego to Canada twice.....
Re: rear diff
Did Andy cut the cheese?
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: rear diff
Andy, you need to talk about the differences between an HO52 and an HO72. Mainly,the load bolt on the pinion.
Re: rear diff
Count the bolts in the rear pumpkin. 14= 1-ton
'70gmc 3/4ton 4X4, re-arch and 2" add-a-leaf lift. '77 400sbc, '82 axles, d60front, 14bolt rear. Probably some 285/75/16 Toyo m/t's on my stock rims coming up. |
Re: rear diff
The center section of the 3/4 ton and 1 ton rears will swap directly back and forth. They have the same number of bolts.
#15 |
Re: rear diff
Tx, every HO52 I have had had the preload bolt.
#16 |
Re: rear diff
Thanks again guys for the help, here's a shot of both the 67 and the 48....A bigger one is on my profile. Plans for the 67 include a Caddie 500/400 turbo, aux tranny, one ton dually rear, disc brakes all the way around and air bags to augment the coils in the rear...
