Old 03-28-2007, 03:18 AM   #1
teamradrz1
teamradrz1's Avatar
WTB: 71 4X4 center link
I believe that is what it is called, the rod that has the tie rods on each end, mine is bent from wheelin so I thought I'd check to see if anyone has one for sale.
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 03-28-2007, 06:32 AM   #2
Re: WTB: 71 4X4 center link
It "is" the tie rod.The ends are called tie rod ends.These are only available used.Make sure threads are in good shape.I replaced one for that reason.
Old 03-28-2007, 07:01 AM   #3
msgross
msgross's Avatar
I have a few for that I can sell. Whats your zip for shipping? Do you need one with a steering stabilizer hole on the end or center? (or none). And what is the length of yours?
How's $25 + cheapest ride?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 03-28-2007, 02:23 PM   #4
Luis_gz06
Luis_gz06's Avatar
They do have those new I believe. It is called Adjusting Sleeve!!
Brotherstrucks has those brand new for $19.95. i bought mine from them and works and fits great. Well am not sure if thats what you need but a pic of the old one would help to identify if thats what im talking about.
Well later, Luis.
Luis_gz06 is offline   Reply With Quote
Old 03-28-2007, 03:46 PM   #5
msgross
msgross's Avatar
Here is what he is looking for, I think. This is one of the three that I have, you can have the tie rod ends too... steering stabilizer is already gone. Note how the factory steering stabilizer hooks onto the center, I have one that has the hole at the end too...
The Garage:
Old 03-28-2007, 06:06 PM   #6
chipflyer
chipflyer's Avatar
I could use a good straight one as well, without the hole for the stabilizer. If you end up with an extra I am interested.
Thanks,
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 03-31-2007, 02:52 PM   #7
teamradrz1
teamradrz1's Avatar
OK mine has the hole on the end not in the middle and it is about 58" long tie rod to tie rod. I have a DANA 44 up front with 3/4 ton axels. But nothing is in the hole and I bought a pro-comp dual shock stabilizer so will that work or do I need the one with the hole in the middle and do I have to have the factory stabilizer on it to be effective or could I use one with no hole since I have the aftermarket stabilizer? HELP
2012 Camaro 2SS/RS
2007 Avalanche 4X4
Old 03-28-2007, 06:16 PM   #8
msgross
msgross's Avatar
The one with no hole is for my closed knuckle 68. what is the measurement of yours?
Will you take one with a hole?
The Garage:
Old 03-28-2007, 10:56 PM   #9
chipflyer
chipflyer's Avatar
Not sure if you are referring to me or not, but take care of teamradrz1 first and if you have one without a hole I would be interested.
Jeff
Old 03-31-2007, 04:59 PM   #10
msgross
msgross's Avatar
sorry for the delay guys, just got back from business trip.
I don't think that it will hurt anything to run without the factory stabilizer if you are running an aftermarket dual setup. It should matter if you have a hole or not either since it will use a U-bolt for your new one. 58" sounds right, do you need anything besides the rod?
The Garage:
Old 04-06-2007, 05:42 PM   #11
chipflyer
chipflyer's Avatar
Hey ms,
Do you have one that doesn't have a hole for the stabilizer? Just a plain round tube?
Jeff
Old 04-06-2007, 06:00 PM   #12
msgross
msgross's Avatar
yes, it's off my closed knuckle. I'm waiting to see if teamradrz1 wants my other one or that one, just sent him an email last night... give it another day or so...
$50 + shipping (probably around $20 to ship)
The Garage:
Old 04-07-2007, 01:32 PM   #13
msgross
msgross's Avatar
did you get my email teamradrz?
The Garage:
Old 04-07-2007, 10:53 PM   #14
va_tlc
va_tlc's Avatar
msgross put me in line also ill check to see which one i need sunday just in case you have a extra one , not trying to jump in front of anyone thou, mines a 3/4 ton also if that matters???? thanks tony zip is 24477,
1969 rs
1966fastback
1969swbc/10
2006gt
1972swb4x4
va_tlc is offline   Reply With Quote
Old 04-08-2007, 12:28 PM   #15
otsenre
otsenre's Avatar
Did you find out whether 3~4 and 1~2 ton tie rods are the same. I would think that they are but not sure, Anybody?
otsenre is offline   Reply With Quote
Old 04-08-2007, 12:53 PM   #16
msgross
msgross's Avatar
I imagine that if there was any difference it would be where the tie rod ends connect to the knuckle.
I started a new thread with mine for sale..
http://67-72chevytrucks.com/vboard/s...d.php?t=235308
The Garage:
Old 04-08-2007, 01:37 PM   #17
454_72_4X4
454_72_4X4's Avatar
The ones with the hole for the stabalizer are a solid steel shaft and have the tierod end made onto them on one end and an adjusting sleeve with a short tierod end threaded into it on the other end, correct?
Those are available new, (or was a couple years ago anyway).
My 72 has a hollow tube with threaded ends on each end for the tierod ends to thread into.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 04-08-2007, 02:13 PM   #18
msgross
msgross's Avatar
my 82 axles are like that but the 76 has one fixed end with a sleeve at the other end.
The Garage:
