03-29-2007, 01:50 AM | #1 |
posi code
does anyone know the code for a factory posi in the 73-87's? i'm headed out to the junkyard this weekend to find a posi rear end, hopefully i will get a chance to look through all of the trucks, but what are some ways to tell if its an posi without taking the cover off the rear end?
03-29-2007, 11:11 AM | #2 |
www.73-87chevytrucks.com
Re: posi code
With the trucks as old as they are there is no way to tell if it is a LSD without removing the cover.
G80 is the option code for them though. In general, the 12bolts have the Eaton clutch style unit, and the 10bolts have the Eaton Gov-Loc.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
03-29-2007, 11:16 AM | #3 |
The Crazy Machanic
Re: posi code
I was told to jack it up and turn the wheel and if the other wheel turn, In th same direction its a posi. BUt i could be wrong been so long sents iv been told that.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day) * 1970 chevelle 2dr sedan Latest update June 24 2007. *1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad) newest additions 1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in and a 79 c60 trash truck um no idea i have one |
03-29-2007, 11:25 AM | #4 |
Re: posi code
If the unit is tight and it is a clutch setup that "could" be fairly accurate, but it the clutches are worn, it will act like an open diff.
The test won't work on a gov-loc though, it uses flyweights to engage, so it will always act like an open until it senses slip.
03-29-2007, 12:23 PM | #5 |
Re: posi code
ok, thanks a lot guys for the info
