03-31-2007, 06:44 PM | #1 |
Separating the steering column from the shaft?
I am in the process of swapping the three speed manual column in my 69 GMC for another 3 speed manual column that I picked up at a wreckers.
I have everything loose and free, but I can't get the splined shaft off the steering column. Any hints or tricks?
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
03-31-2007, 06:57 PM | #2 |
Re: Separating the steering column from the shaft?
there is a bolt in the coupler that has to come out i spented 4 hour the other week trying to remopve mine before i found this out the bolts in the couplers have to come all the way out
03-31-2007, 06:59 PM | #3 |
I have the coupler bolt right out, but it is still stuck. I had looked at my replacement and saw that the shaft had a small flat section, but not all the way to the end.
What did you do after the bolt came out?
03-31-2007, 07:16 PM | #4 |
i use a wedge chisel to spread the coupler to remove the splined shaft
03-31-2007, 07:38 PM | #5 |
The coupler seems loose, but the shaft will not come out.
Is the end of the shaft spring loaded?
04-01-2007, 01:30 AM | #6 |
Anybody else?
04-01-2007, 01:33 AM | #7 |
A picture please. What year is the wrecker column?
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
04-01-2007, 01:45 AM | #8 |
when i replaced my column the shaft was one piece fron the rag joint to the steering wheel nut i pulled the whole thing through the dash (from the rag joint up) then i put my new tilt next to the old one and cut the steel shaft how long i needed it and then bought a u joint to conncet it
any other questions just pm me
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
04-01-2007, 09:28 AM | #9 |
pb blaster
04-01-2007, 03:38 PM | #10 |
It's out, thanks everyone.
I ended up removing the intermediate shaft at the steering box and taking it out as a unit. Once on the bench a small pry bar was all it took to separate the two. Now to get the new one back it......
