04-01-2007, 05:00 PM | #1 |
anyone know the cheapest place to buy a horn??? mine is busted
my horn does not shut off is there a way to fix it?
04-01-2007, 05:10 PM | #2 |
Re: anyone know the cheapest place to buy a horn??? mine is busted
chances are its in your steering column or steering wheel especially if you have a non stock wheel// start by taking the wheel off
04-01-2007, 05:27 PM | #3 |
it would not stop even when i had my stock column on....it just one day once i pressed it just would not go off
04-01-2007, 08:43 PM | #4 |
Cantankerous Geezer
It's usually one of three things. 1. The button in the column is stuck down. 2. The wire inside the column is shorted. 3. The relay (on the firewall near the column is bad.
The wire from the relay to the button is a ground. If you disconnect this wire and the horn stops honking, the problem is in the column. If it continues the problem is the relay.
Fred There is no such thing as too much cam...just not enough engine. |
04-03-2007, 10:33 PM | #5 |
yes call ed from moter trucks 18667556772
04-03-2007, 11:33 PM | #6 |
Neighborhood Pickle Slinger
1. Open the hood
2. Find the horn. 3. Cut the wires going to it. 4. Should be off now. Just kidding. FredT posted the same answer I would have wrote. Did you ever get it fixed?
-------------------------------------------------- My C10 Diary Our cars: 1966 Chevrolet Chevelle 396 - TH350 1968 Chevrolet C10/CST 327 TH400/375 1969 Corvette Stingray 350 - Muncie Manual Trans 1969 Chevrolet ElCamino 350 - TH400 1970 Cutlass Supreme Convertible - 350 Rocket - TH350 1973 Camaro LT - New Engine Done - TH350 1973 Corvette Convertible 454 - TH400 Last edited by blukangoo; 04-03-2007 at 11:35 PM. |
