04-01-2007, 06:14 PM | #1 |
A starter 15 year plan
Hello everyone. Name's Travis Hageman, location Wisconsin. Have this 66 pickup with what I believe to be a 292 inline 6, matched to a transplanted 3 speed from a pontiac car. Gear shift was switched from 3 on the tree to a hole cut in the floor by a previous owner. Havent got much of a history on the truck, as its had many previous owners.
Bought it for 300 bucks cash, had no front bumper, no tail lights and no bed. Built the bed myself using treated 4 by 4s, 8 or so 2 by 4s and 2 pieces of 1/2 inch plywood. The fenders are from farm and fleet, drilled to be screwed on. Had the heavy duty tube rear bumper on it from the get go with slots cut for taillights, so I wired up trailer lights for the inside. Also bought a set of used 16 inch wheels and tires from a guy I used to work with. Plans are to make it a functional working truck, sans wood bed. Would like to have a late model bed floor put into the box so it can be rhino or linex'd. For an engine, 502 crate most likely, big block for sure. And then either a 5 speed manual or a 4L80e automatic. Like to also do a front brake disc conversion from a newer 3/4 ton. My personal history, went to WyoTech, gradutated with a degree in Automotive service management and with honors in my class. Worked at a Chevy dealership for a year and a half, then now I'm a motorcoach driver for a local company. I did obtain my ASE Master tech Certification. I should have enough knowledge to piece together this beast. I'm about to get married soon, so funds are really tight. Being I rent currently, I'm not allowed to "tear apart", but only to "maintain street legality". Runs and drives pretty reliable. Put 4 thousand miles on it last summer. Always looking for parts, but not so much the expensive ones. -Travis |
04-01-2007, 06:50 PM | #2 |
Re: A starter 15 year plan
Travis,
Nice truck. Glad to see another cheesehead here. I'm new here too, and also working on a '66. Tom |
04-01-2007, 09:03 PM | #3 |
Cantankerous Geezer
Looks like a good start. Not being able to work on it will let you save up some money to buy parts.
Fred There is no such thing as too much cam...just not enough engine. |
04-01-2007, 10:14 PM | #4 |
nice start
04-01-2007, 10:27 PM | #5 |
very nice start, that cab looks like its in great shape.
I see you also have an invisible throttle pedal. |
04-01-2007, 10:32 PM | #6 |
very cool !!!
04-03-2007, 12:25 PM | #7 |
No photos of the underside yet, but it's missing a cab mount on the passenger side under the floor. Previous guy welded in some angle iron... Hack job if you ask me. Also, how common were the rear cab mounts? They dont sit on a donut, as its a flat piece of metal going straight down with rubber on the inside, then another vertical flat piece mounted to the frame. Like a cab mount sub sandwich up and down.
