Old 04-03-2007, 11:51 PM   #1
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Big 2.5" Vette Ram Manifolds---Fit 2WD! and 4WD
I have been doing some special fitting on these, for those of us who do NOT want to run headers, but do want better flow from ramhorns. We know these have been a good upgrade for 4WDs, in the past, but not 2WDs. They wouldn't clear the big crossmember under the engine or the starter on 2WDs.
The bend coming out of the straight down Vette rams has to be real tight to clear and muffler shop machines can't do that bend without flattening the pipes.
So, you have to use mandrel bent 45 degree pipes and really shorten the upper part of the bend. The flares have to be welded on because the machine can't flare that short of a pipe...I didn't say it was going to be real easy.
We almost have it now. The answer to the stock starter clearance is using a late model/common 350/4.3 mini starter.
I sell the manifolds, new in the box, for $130 delivered, if you want to DIY. You chase down all the small parts & weld...OR (you know there would be an OR...)
I can provide the fully prepped package (without starter): $330 + shipping
1. Manifolds fully prepped: ends cut off, dressed surfaces, blasted, & baked on high temp paint (no guarantees, but better than raw cast surfaces).
2. Gaskets, flanges, high temp flange seals, & studs.
3. 45 degree mandrel bent aluminized pipes with welded flared ends.
...and here's some pics...
PICKMUP is offline   Reply With Quote
Old 04-04-2007, 12:23 AM   #2
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Thumbs up Re: Big 2.5" Vette Ram Manifolds---Fit 2WD! and 4WD
Just thought I'd help you out an give praise to these. I have experience with these manifolds (circle track when manifolds were required in certain classes)and can't say how much I like em'. I have seen cases were these actually perform better than some headers. Very good deal IMO buyers will be happy.RJ22
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-04-2007, 03:38 AM   #3
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I will offer free studs and gaskets with the bare manifolds for the same price: $130 pr delivered
NOTE: The bare manifolds do not include any pipes and have no prep work done to them...
Old 04-04-2007, 09:22 AM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
How much for a set of manfolds with prep work completed? ie, ears shaved and any cast welding needed.
David
D.PASSMORE is offline   Reply With Quote
Old 04-04-2007, 09:57 AM   #5
msgross
msgross's Avatar
since I have a 68 k-10 w/ the alt mounted to part of the driver manifold can I run these? $130 shipped to my door? Mine are frozen to the old down pipes and I don't want to run headers... Thanks. What about painting or ceramic powder coating them?
Mike
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-04-2007, 12:23 PM   #6
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
DP-There is no welding needed or done to the cast/manifolds...you just have to weld on the flares on the down pipes. Just cut off the ears and smooth the manifolds up with a hand grinder/sander for appearance. "DIY" and save.
MS-If you have holes in your heads, just run a 69+ alt brkt set...If not, you will have to get or make an aftermarket alt brkt. Yes you can have them ceramicoated or high temp painted. DIY and save.
Old 04-04-2007, 04:27 PM   #7
msgross
msgross's Avatar
are you saying I have a hole in my head? You must have talked to my wife!
Let me see if mine are salvageable, what kind of quantities do you have of these? save me a set until the weekend if you would...
The Garage:
Old 04-04-2007, 03:29 PM   #8
3/4tonterror
3/4tonterror's Avatar
Pm Sent
3/4tonterror is offline   Reply With Quote
Old 04-04-2007, 08:54 PM   #9
uncle
I'll take a pr. of the bare ones with gaskets and studs. PM me your paypal address or preferred payment.
uncle is offline   Reply With Quote
Old 04-04-2007, 11:07 PM   #10
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I am not exactly sure on the quantities available, because these are a new release and we don't know what to expect on sales volume/action.
I am only buying one side from the Vettes (the best one with no heat tube) and using it for both sides of our trucks. I warned them that I would be breaking up their pairs, so I hope they don't run out or make price adjustments!
Old 04-05-2007, 12:02 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Folks, having done some research on the 2.5 Corvette Ramhorns I can tell you this is a smoking deal. I paid almost that much for "one" manifold, and that did not include delivery.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-05-2007, 12:23 AM   #12
ZOOMY
I'll take one pair with studs & gaskets. PM me your Paypal address & I'll pay right away............Zoomy
ZOOMY is offline   Reply With Quote
Old 04-05-2007, 12:46 AM   #13
1LoC10
Insert Title Here
1LoC10's Avatar
the mandrel pipes are 2.5" I would assume
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 04-05-2007, 12:50 AM   #14
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
So these will work on a 283? In a 4x4?
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 04-05-2007, 06:20 AM   #15
vtblazer
vtblazer's Avatar
Hey guys, they work out great.
Just installed a set on my 4x4.
Frank is correct about the first bend, it was a tough one to work around.
I'd recommend getting the kit he's offering, it'll make the install alot easier.
vtblazer is offline   Reply With Quote
Old 04-05-2007, 07:30 AM   #16
olblue60@aol.com
member
Hi Frank
I'll take a pair, with just studs and gaskets. Pm me your paypal acct too. Thanks !
John
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 04-05-2007, 08:05 AM   #17
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Frank,
I'll take a set with studs and gaskets, Could you post your paypal info for payment?
Old 04-05-2007, 12:18 PM   #18
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Canadian: They have the standard SB chevy exh bolt pattern that fits all normal/regular SB engines.
1loc10: The exit pipes are 2.5'. Our stockers are 2"---BIG differece!
PayPal Address is: frankeham@comcast.net
NOTE: The gasket/stud sets I am including as a special bonus were originally for the stockers, so you do have to go to auto parts and get the big donut seals. I use the ones from '88 & newer because it is better material and has a stepped edge to keep it in place in the manifold. Much better.
Old 04-05-2007, 01:17 PM   #19
RED71CHEVY
RED71CHEVY's Avatar
great prices, i will take two sets, one set with the extra ear, and one set without. email me for payment.
thanks,
tim
TIM
'71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!!
RED71CHEVY is offline   Reply With Quote
Old 04-05-2007, 01:21 PM   #20
RED71CHEVY
RED71CHEVY's Avatar
can you show a set on a 2wd, i would like to see how tight it will be......and also to see how much room there is and if i need to think about ceramic coating for heat.
tim
TIM
Old 04-05-2007, 09:54 PM   #21
Canadian694x4
Born To Lose Club
Sent you a PM...
Old 04-05-2007, 11:06 PM   #22
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Here are some pics moched up on a 2WD with the motor in the tight forward position. There is good clearance around the mini starter.
4x4s in the rear position clear just like they did with the stock rams & stock starter.
Old 04-05-2007, 11:19 PM   #23
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Payment sent
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
Old 04-06-2007, 12:06 AM   #24
ZOOMY
Frank, Payment and address sent..........Z
Old 04-06-2007, 09:57 AM   #25
RED71CHEVY
RED71CHEVY's Avatar
my eingine is back in the 6cyl holes (didn't move it when i chg'd to the sb), so you are saying i will have more clr because i am farthe back on the saddle? so i can make a longer vertical drop before turning to the rear? and still use a std starter? if this is so, then it is a good thing that i used the 6cyl mounts and position! other than tight being at the hei cap ( about 1/2-3/4 clr of wall).
tim
TIM
