front crossmember swap?????
ok yall. as some of you know i have a 1984 chevrolet C10 coming. i was wondering how much work it would be to switch the front crossmember over to my 1966 C10. what all would have to be done? also will the master cylinder bolt strait up to my 66?
thanks, John
Respect: 1. A feeling of appreciative, often deferential regard; esteem. 2. The state of being regarded with honor or esteem. 3. Willingness to show consideration or appreciation. When you fail to show consideration to others values you are showing disrespect. |
Re: front crossmember swap?????
btw, i mean the whole front crossmember and suspension and brakes and everything. forgot to mention that.
thanks again, John
![]() Join Date: Sep 2006
the master cylnder will bolt up but you have to cut the arm going to the brake pedal and do some fab work for it to work.. You don't have to use the whole crossmember.. Look at the STICKY at the top of this post as it is all in there...
