Bite me, import boy
Instrument cluster panel for aftermarket gauges
I am looking for an aluminum panel to fit in the stock location to mount a set of aftermarket gauges on a 65. I've seen them for the 67-72 and early pickups, but I haven't found anything for 63-66.
Thanks, Jason
Jason '71 C-10 Deluxe-under construction '69 C20, 396,T400-donor truck, '65 C10 project "Facts are meaningless, You can use facts to prove anything that's even remotely true." |
SIR
Re: Instrument cluster panel for aftermarket gauges
...haneline gauges and panel... www.haneline.com
66long low fleet http://community.webshots.com/user/LVNR66 Last edited by SIR; 05-06-2007 at 01:15 PM. |
I love the gauge/dash setup thatg SIR has from Haneline. There is also another version using autometer gauges at http://brothersonlinestore.com/prodi...number=CGP6600 Personally I like the Haneline set up better. What gauges did you use SIR?
#4 | |
![]() Join Date: Sep 2006
Bite me, import boy
Thats exactly what I need. I thought I had seen them before browsing for parts on my 71, but when I looked back through my catalogs I couldn't find them again.
Thanks, Jason
SIR
....very well no issues what so ever..very pleased.......
66long low fleet http://community.webshots.com/user/LVNR66 |
#7 | |
vince |
![]() Join Date: Oct 2006
How about a cheep home made one ?
![]() Join Date: Nov 2006
Anyone know if someone makes an insert for a GMC?
60-66 Nut
In the past I've had to make them myself. The GMC's are a little more work since the gauge panel and the bezel are one piece. You just have to cut them apart, leaving a lip on the bezel so you have a place to attach the new gauge panel. IIRC there is a groove that you can cut in as a guide and it leaves enough of a lip.
Bite me, import boy
kwkenuf,
Is that a copper color, or is it just the lighting? Jason
Retrofit Management
Nope, it's actually just polished aluminum.. poor picture I guess....
My retrofit fleet -1966 Suburban 2002 Tahoe drivetrain, firewall, floor, chassis and interior in progress -1965 C-10 shortbed stepside, 2003 5.3/4L60E conversion. Power steering, tilt wheel, power front disc brakes, 2.5/4 inch drop, relocated fuel tank and battery, 2002 Silverado buckets and console. Swap Pics -1968 Camaro 95 LT1/4L60E lots o' mods Web Page -1961 Corvette project Corvette Corrections frame, C-4 suspension and brakes, 02 LS1/T-56, Never ending body workPics |
Bite me, import boy
Thanks to everyone for your responses.
Jason
Retrofit Management
Ebay for the aluminum panel.
#15 |
We sell these. They are custom made they are a two panel set. The gauges mount to the inner panel and the outer panel fits over to cover up the rim on the gauges. Its just a little different. They can be powder coated. We do not sell them polished as it tends to scratch easily. They only fit Autometer gauges which we can provide if wanted.
#16 |
I don't know if anyone else has noticed but on ebay I always see the same old stuff like fenedrs, rockers cab corners. I know you always have to keep checking which I do, but there dosen't seem to be many good used parts for these trucks.
#17 |
Cantankerous Geezer
The color appears to be anodizing. It's a coating process used on aluminum, can be done in several colors. Relatively hard surface. When done properly, it won't peel or scratch in normal use. We used it a lot on aircraft parts.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#18 |
I got mine from Dolphin gauges.
