04-06-2007, 09:50 AM | #1 |
1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
Need Some Help with Header Gasket Problem
Ok so i am driving home from work last night and i here a little pop in my exhaust. Like no back pressure .... as if it wants to backfire but doesnt. So i get home ok and i open up the hood to find that i have blown out my driver side header gasket. I kinda knew this was coming, just not so soon. I put some cheap Felpro gaskets in there hoping they would get me around till i got the truck in for the new exhaust but i guess i was wrong.
So my question for you exhaust buffs is what gaskets are you guys using? I need some that are a bit thicker then norm and WILL NOT leak .... i cant tell you how bad i hate exhaust leaks. If you guys could give me some links to them or maybe some pics i would really apreciate it. The sooner the better cuz i am now without a car seeing how the truck is my daily driver. Thank you in advance! -Hart
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project Last edited by JHART; 04-06-2007 at 09:51 AM. |
04-06-2007, 10:01 AM | #2 |
Re: Need Some Help with Header Gasket Problem
i use felpro, the secret is a header with a thick flange and do not overtighten the bolts and warp the header. Buy bolts with locks in them because when they loosen up a little the gasket will blow out. Retighten the bolts after the first half hour of use and check once in a while
04-06-2007, 10:11 AM | #3 |
tiggerstoy
still use felpro, but you can try and use copper ones, just make sure to re tighten after a half hour of running them, they work great, and you can reuse them if you need to.
04-06-2007, 11:15 AM | #4 |
sbc have a problem with header bolts backing out i agree with useing the locking type bolts but i also put a small dot of red locktight on the ends just for that bit extra
04-06-2007, 01:41 PM | #5 |
I cut the header flanges on each side of the center tubes and I use regular manifold gaskets. The manifold gaskets have the little ears on them and you can start all your bolts and just drop them onto the bolts. I am using stainless bolts so you can't really tighten them a lot. I have not had one come loose yet. Cutting the flanges allows the bolts to be started easier also. It works very well and costs very little. The gaskets run about 6 or 7 bucks.
04-06-2007, 01:48 PM | #6 |
I survived Dead Man's Curve.
I make an attempt to tighten every header bolt atleast once every two weeks. I've had those bolts come so far out of the head that I could pull the header away from the head partly.
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. |
04-06-2007, 01:54 PM | #7 |
Cut the flanges............ They are probably warped from when they welded the tubes to the flanges. It works and you can forget about them!!!!!!!!!!
04-06-2007, 02:22 PM | #8 |
Hmmmm, I never heard about cutting the flanges... but I'm going to try it on my big block headers. Got the same problem of blowing out gaskets every few thousand miles.
The Fastor Pastor '68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed: '70 swb; TH-400 - bagged & shaved. Looking for new engine or parts. Wife - Original {A Real Classic!} |
04-06-2007, 02:34 PM | #9 |
The guy that told me abut doing this about 16 years ago has had all big blocks and he's never had a problem with bolts backing out. I asked him about it not long ago. He's a drag racer.
04-06-2007, 03:17 PM | #10 |
1972 Shorty Owner
So should i bother getting better gaskets or should i just go to Kragen and pick up some cheap ones? I'm going to cut the flanges also thats an awesome idea!
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project |
04-06-2007, 03:20 PM | #11 |
i use mr gasket copper and put loctite on the bolts never had a problem
04-06-2007, 03:45 PM | #12 |
i doubled them up on mine and it worked fine
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
04-06-2007, 03:50 PM | #13 |
I use the manifold gaskets. Three to each side. Never had one to leak.
04-06-2007, 04:03 PM | #14 |
1972 Shorty Owner
three? Man i hope i dont need that many.
You guys know where i can find some new bolts ... the locking type? I should probably heat these old bolts up before i try pulling them out right?
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project Last edited by JHART; 04-06-2007 at 04:41 PM. |
04-06-2007, 07:44 PM | #15 |
There are 3 indiviual gaskets for one side. One each for each single tube and a gasket for the center two. If you cut your flanges chances are you wont need the locking bolts.
04-06-2007, 08:10 PM | #16 |
1972 Shorty Owner
Sweet thx for the help Mudder. I plan on taking them off this weekend and make the cuts/gasket replacement.
