04-07-2007, 10:07 AM | #1 |
Anyone use this?? TCI 700R4 Valve Body
TCI has a new constant pressure valve body for the 700R4/4L460 tranys that's supposed to maintain 200 psi all the time and eliminate the critical shift-point adjustments. You still need to set-up the cable but the valve body keeps the pressure high enough so you don't burn up the trany if your adjustments aren't right on.
HAS ANYONE USED THIS YET ???? Part # 376020
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
04-07-2007, 10:50 AM | #2 |
Cereal Killer
Re: Anyone use this?? TCI 700R4 Valve Body
Im planning on using that valve body.
Bob Harrison is the guy at TCI that completed the project. He is a kick ass tranny guy that used to live in my hometown. He left bama to goto ArtCarr and then came to TCI a few years ago.
If I dont do it....somebody else will. |
04-07-2007, 02:00 PM | #3 |
I used their Full-manual Reverse pattern valve body on my old truck's 700r-4. I don't know if it was the 376010 or376015, they only had one version in the early 90's when I got it. I know it's not the same thing as what you are looking at, but that was a Great piece. I'm just letting you know that they are a quality supplier and if they say it should work, I'd believe them.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
04-07-2007, 02:38 PM | #4 |
GEARHEAD
I have never used any of their 700r stuff but I have used their th350 and th400 valve bodies and kits and I am very satified with the quality of their prducts in general.
04-09-2007, 08:01 AM | #5 |
Sounds like TCI makes good stuff from the replies but I would stiil like to hear from someone that has used this valve new body for the 700R4's. ANYONE ???
Gary
