Old 09-06-2002, 01:55 AM   #1
71MoneyPit
MPG...hmm..more like GPM
71MoneyPit's Avatar
Smile Caddy Engine Pics
here's the Caddy Motor pics and driveshaft pics you guys wanted to see Please excuse the mess in the pics, it doesn't look that great right now because im redoing the wiring. ok here goes the first one...
(Looking for 67-72 shortwide or shortstep bed)
71 C-10, 500ci of tire shredding Caddy torque, th400, 12 bolt w/Powertrax Lock-Right. Bald Rear Tires
85 Toyota 4x4- 22r 4-banger, 5 speed, I can actually AFFORD to drive this one.
71MoneyPit is offline   Reply With Quote
Old 09-06-2002, 01:58 AM   #2
71MoneyPit
71MoneyPit's Avatar
another engine shot(fan is off because im having to space out the pwr steering pump pulley to match the others, because im not using the A/c Compressor)
Old 09-06-2002, 01:59 AM   #3
71MoneyPit
71MoneyPit's Avatar
last engine shot-little higher view
Old 09-06-2002, 02:02 AM   #4
71MoneyPit
71MoneyPit's Avatar
Drive shaft
heres two pics of the driveshaft-its a custom aluminum drive shaft.
The second pic shows the Caddy Slip Yoke
Old 09-06-2002, 02:04 AM   #5
71MoneyPit
71MoneyPit's Avatar
heres the Caddy end
Old 09-06-2002, 02:09 AM   #6
71MoneyPit
71MoneyPit's Avatar
tranny crossmember
here's two pics of the crossmember(don't mind the always useful Wal-Mart Plastic bag covering the end of the tranny )
Old 09-06-2002, 02:11 AM   #7
71MoneyPit
71MoneyPit's Avatar
2nd one( notice the long snout on the tranny)
Old 09-06-2002, 02:14 AM   #8
71MoneyPit
71MoneyPit's Avatar
Last pic
this is where i had to cut for the oil filter
Old 09-06-2002, 03:12 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What mounts and towers are you using?
Old 09-06-2002, 07:12 AM   #10
umrebelsfan
That is not the frame you cut for oil filter access is it? Looks like a pretty big hunk. If it is I think you ought to weld it back in and get a remote filter kit. JMO
67 Short Step 250
umrebelsfan is offline   Reply With Quote
Old 09-06-2002, 08:28 AM   #11
kxmotox247
kxmotox247's Avatar
Look like a tight squeeze. A lot of effort to be different.
kxmotox247 is offline   Reply With Quote
Old 09-06-2002, 02:27 PM   #12
71MoneyPit
71MoneyPit's Avatar
longhornmail-I had some people at a shop I know custom make the motor mounts( i just noticed i could have bought universal motor mounts from CMD and saved a little money but oh well ) and the tranny crossmember was welded by them too( im not the greatest with a welder, just learning) but I put the motor and tranny in. I figured id let them fab the stuff so it was done right.
umrebelsfan-no its the front crossmember right below the front of the motor( the pic was kinda decieving,I took the picture a little close.)
kxmotox247- yes its going to be tight once i get the fenders in there isn't going to be much room under the hood but it'll be worth it. I could always go for the sleeper look and put the badges on the front fenders that say 307 and quiet mufflers,suprise the heck out of wannabe racers thinking its just a crappy old truck
Old 09-07-2002, 08:53 PM   #13
umrebelsfan
I'm a big caddy fan as well. Those engines may not always be quick but they are smoooooth once they get to speed.
I had a 67 convertible. 429 engine was a great one as well. Frank Sinatra stuck in the underdash cassette because God wanted it that way. Huge seating areas and trunk. Got me started on quest to own one of all the GM lines in 67. What a year!
67 Short Step 250
