04-09-2007, 07:26 PM | #1 |
whats the SPECs of your truck
well heres mine is "Blue" it started its life as a 70 chevy C30 1ton flat bed 2wheeldrive went with a 86 chevy 3/4ton frame with a 8 lift in the front an a stack of two 3/4ton leafs with shackle flip in the back, got my axles off of an 78 dodge snow commando 3/4ton Dana6o open diff and a chevy 14 bolt thats welded with rear with disc brakes,it has 4:10 gears, rolling on 44s TSL in the front and Boggers in the rear,6AL MSD, HAD a built 350 small block, 350 trans with a 203/205 doubler transfer case with a triple stick , crossover steering, custom bumpers and i can not forget about my Co-poilt "Ducky" and now im working on a new project only a hand full of people knows about soooo
Upgrade: body swap to a 68 suburban, military 2 1/2 Rockwell axle, Bigg Block, and 56 tractor tires Last edited by Towstrap; 04-29-2007 at 02:02 PM. |
04-10-2007, 08:12 AM | #2 |
Re: whats the SPECs of your truck
Nice build, Towstrap.
My 71 one ton Blazer specs: Front to rear. *3/8" steel front bumber holding in the Warn 9.5K winch *69/70 grill cause it looks alot better than the tube one that was on it *Tranny, steering and engine oil coolers *4 core rad with modified cowl and two speed electric fan *TBI'd 383 stroker motor w/serp belt set up *2.5" center dump vette rams horn manifolds with x-over and FlowMaster mufflers *Factory tilt column with newer GM leather wrap wheel *High pinion Dana 60 from a 79 furd w/5:13's *Cross over steering *4130 axles with spool and beefier u-joints *PSC ram assist steering *One ton front shaft from High Angle with a 12" slip *Built th-400, extra clutch, bigger spragg count, blah-blah but built tough *203/205 doubler with triple sticks and skid plate *High Angle double cardon shaft out back *14b FF with disc's, Detroit locker and 5:13's from a 98 Chevy *6" Alcan springs with shackle flip that puts it to about an 8" lift *40" TSL's with Staun internal bead locks on steel 16.5x9.75 wheels *Full family cage *Corbeau seats with 4-piont harness *Rock sliders in place of rocker panels *Fuel cell with internal pump in factory location that only hangs 3.5" below the frame intead of the original 7.5"s *Flush mount fuel door to replace the tree catcher *Hard top and soft tops *3/8" steel basically square back bumper So that's the basics. Last edited by vtblazer; 04-10-2007 at 08:16 AM. |
04-10-2007, 10:21 AM | #3 |
vtblazer Nice
any others Last edited by Towstrap; 04-10-2007 at 10:21 AM. |
04-10-2007, 11:15 AM | #4 |
72 chevy
Both of you guys trucks sound really nice.
I have a 86 blazer with a 383 and 40 groundhawgs on it. A small lift with the fenders almost cut of front and rear its easy to get in for me though. Its preaty much stock with the 10 bolt rearend welded. It gets me around good. My 72 k10 LWB is going to be a little bigger with 3/4 ton drive line and i hope soon to have 39.5/16 boggers on it. Ed |
04-10-2007, 11:22 AM | #5 |
Well, mines a work in progess.
It's titled as a '69, but has '68 cab & dog house on it. "Stock" were still applicable, read sig... 307 V8 replaced with 350. D44 in front - looking for D60 - will be locker. 12 bolt in back - 14bolt getting closer to going in - will be det. locker, I think. Want a winch, and I think it'll be the truck I'm after... Nice rides guys - I don't do near the thrashing that y'all do, just a good work/play truck.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
04-10-2007, 12:33 PM | #6 |
Ok I'll play..avoiding my work hehehe
1972 K5 new to me in 1993 454 = board 30over, inlarged valves in 781heads,Comp cam,Mallory ignition,EdelBrock Pro-Flow MPFI, balanced, decked & shaved. ORD engine mounts & crossmember, dual Felx-A-lite elc. fans. Dyno tuned giving me 286Hp & 390Tq AT the rear tires, baiscally alot of fun to drive Thorley Headers w/2.5"pipe and 50seires Flowmasters & a H pipe Dual Optima Batts w/Hellroaring iso/combiner Mico Lever-Lock (line lock for the front brakes) Sm465 w/Luk ProGold clutch assy. & hydrolic swap out the manual linkage Np205 stock except for the poly mounts Front = D60 (currently being installed) Lock Rite, 4:56 Yukons(the rest is stock for now) DIY4X Razorback cover WFO Crossover/Highsteer setup, heavy duty version (rods,arms,TREs, etc..)( currently being installed) PSC Hydro assist kit (gearbox, pump, 8"ram)(currently being installed) 4" spring lift Rear = 14FF w/disk brakes Detroit locker & 4:56 Yukons(currently being installed) 5.5" spring lift H1 8 bolt recentered double beadlock wheels w/PVC inserts 36-13.50/16.5 Irok biasply Swampers 37gal NWMP tank Homebrew skidplate 6pt roll cage 1/4" steel bumpers = Front made by KMA and modified by me. Rear gate/bumper made by me. Other stuff like Co2 PowerTank and Tuffy centerconsol... Oh and I stuffed my factory guage cluster with AutoMeter guages. FastTrack softtop too.. I think that about does it for ht emain items... Burt
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks Last edited by Burt4x4; 04-10-2007 at 04:36 PM. |
04-10-2007, 12:45 PM | #7 |
Oops forgot about my CO2 Power Tank. (thanks Burt)
and the current photo. |
04-10-2007, 01:07 PM | #8 |
Well now were even cuz your pic reminded me about my Warn 9500 winch I forgot to list
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
04-20-2007, 10:19 PM | #9 |
The 71.........350 bored .06 over.RV cam,edelbrock intake/carb.Rebuilt TH350,NP205.Rebuilt front and rear axles.44 front,12 bolt rear.6" suspension lift (all spring lift).35" Pro Comp Mud Terrains Body,rusty now,will be solid and straight eventually.It has parts spanning across the 67-72 era.Atleast one part from every year.Also has some 72 K5 Blazer parts.
The 79......Worn 350,Rebuilt TH350,NP203.4" lift,33s.Just basically keep around to haul parts... The 69 (not pictured) is pretty stock.Except the wheels,tires,and lift.It will be transforming to a K30 later this year.Nothing worth talking about on it at the moment Top pics are of the 71(while motor is out being rebuilt. Bottom is the ol 79 attempting with the 5 or 6 cylinder motor (worn out badly!) and 3:73 open axles to climb the rock pile Last edited by 1969k10stepside; 04-20-2007 at 10:21 PM. |
04-20-2007, 11:14 PM | #10 |
Here is mine 61 4x4, 283 bored .060 edelbrock carb, cam & intake, sm420, rockwell t221 transfer case, dana 44 closed knuckle front soon to be changed to an open knuckle, gm 12 bolt rear. 3.08 gears and 265/75/16 inch tires. Basically stock. Soon to be painted, one day!
04-20-2007, 11:44 PM | #11 |
72 K20, 350,sm465/205, dana 60 front w/ detroit truetrac, 14 bolt rear detroit locker, 4:10 gears, 6" tuff country spring lift, 38-13-16 superswamper tsl's, sorry no pics yet.
almost forgot, 4 wheel disc brakes. Last edited by 1969k10stepside; 04-21-2007 at 12:01 AM. Reason: merged posts |
04-21-2007, 10:53 AM | #12 |
`72 K/20,350,SM465/205,Centerforce Dual Friction,HO52/Detroit Locker/4.10,6" TuffCountry,12.50/35x16 ProComp Xterrains.Dana60/TruTrac & 37" SuperSwamper SSRs on the sideline.Thinking on a LocRight,though.
04-28-2007, 11:02 PM | #13 |
pretty calm turck...
1968 K-10 SWB fleetside, 2nd owner, Original: 327 cid, 4 bbl, 4 speed, tow hooks, HD cooling, bench, marker lights, tach, West Coast JR mirrors, Added: front Corp10 discs, posi rear, rear add-a-leaf, 33x10.5 TA's, 15x8 MT's, SS brake lines, NOS wood floor, rear Reese hitch, power steering, 1 ton brake system, rear poly tank, poly bushings (everything), tilt wheel, urethane coated frame and suspension, Possible upgrades:Rancho 9000 in cab system, Buddy Buckets, Halogen lighting upgrade, paintjob!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 04-29-2007 at 08:47 AM. |
04-29-2007, 12:17 AM | #14 |
i have a 1969 k-10 witha 350. what would have been the stock rearend and front end.
04-29-2007, 01:48 AM | #15 |
Tool Addiction=Money Shortage
My sig says it all, but it will soon have a shackle flip so I can get rid of the blocks.
1967 K20 400TBI SM465/NP205 posi front, Detroit locker 4.56 rear |
04-29-2007, 08:45 AM | #16 |
12 bolt in the rear and closed knuckle (w/drum brakes) dana44 in the front stock.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
04-30-2007, 03:13 AM | #17 |
my 93 is currently under the knife...
out with the 14SF, IFS... in with a HP60 and a 14FF. 5.13 gears in both, Detroit in the rear along with discs using Sky manufacturing brackets. stock 4L60E is in the shop getting beefed up, should be done by Tuesday, and it will be backed by a NP241 outfitted with a JB conversions SYE, HAD flange. both shafts will be built by HAD. springs are 4" TC EZ Rides in the front, 3" TC EZ Rides in the back. ORU brackets in the front, ORD shackle flip in the back. 17" black DC1s, wrapped in 37 x 12.50 Goodyear MTRs (should be in VERY soon, were on national backorder) |
04-30-2007, 05:07 AM | #18 | |
We need pics of it for sure. What's the intended "use"? Will it be a driver/weekend trial ride? |
04-30-2007, 07:00 AM | #19 |
I have a perfect truck to do all this to.A`92 K3500 5spd 6.5TD.And the 6.5 is a marine-duty 300hp!!If I can come up with another work truck w/o selling this,that`s my plan.It`s been the plan since I factory ordered this truck.I even have a RH-drop NP241 to "pop" in there so I can use one of my GM D60s.I`d like to keep it looking factory just to be subtle(and mess with a few minds.
04-30-2007, 09:40 AM | #20 |
1979 Chevy Suburban. 350(Weiand single plane aluminum intake, cam, flat top pistons), SM465/NP205, Dana 44 front/Eaton HO52 rear (welded), 4.10 gears. 6" suspension lift, 38.5x11x16 TSL Boggers. Warn front winch bumper, roof mounted spotlight, CB radio, 2 speed school bus fan (roof mounted inside). Has an '88 tub with Silverado trim. All gauges and vents still work.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
04-30-2007, 08:31 PM | #21 |
Guess I'll post up too!!!
1989 K3500 reg cab long box 454TBI all stock, runs 100% perfect TH400, 2wd from a short bus, 208/241 adaptor, 2" thick spacer machined to fit Ford t-case Ford 205 case, twin sticked, just need to get some levers HP60 from 78 F-250, Powrlok, 4.56s, GM outers from the knuckles out, calipers ground to run 15" rims 14ff from a 93 3/4 2wd, (pull off drums) 4.56s and a Detroit Stock shafts front and rear for now, but hopefully can afford a HAD 1410 CV shaft up front, and will be getting a 1410 rear shaft Currently has ORU SAS kit, but taking that out and gonna make my own, moving the axle foward an inch to clear fender/firewall Homemade shackle flip, 6" Procomp springs, 2wd lowering shackles, 73-87 front hangers (about 2" lift) Currently has 8" Superlifts, but have a set of BDS waiting to go in when I redo the front crossmember 40" boggers on 15x12 Bart wheels, 8 lug with 3.25" BS. Cutout fender flairs Not a straight panel on it. If I can sell some stuff, a doubler is gonna go in, along with a rebuilt 400/203 that I picked up for $100. (Not rebuilt yet tho) Only pics I have are in my sig, but I just took some more today, need to get them put on a disc. I put my stock 93 S-10 Blazer next to it, and the top of the Blazer is about the height of the bed. Here is a pic, about 6" bigger now.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
